Dumb cooling system question
Old Sep 6, 2006 | 09:32 PM
350SS's Avatar
Default Dumb cooling system question
On an LSx (or any other GM motor), does the water enter the radiator from the top and exit the bottom or vice versa?
Old Sep 6, 2006 | 09:34 PM
LS1-450's Avatar
Enters the bottom & exits the top
Old Sep 6, 2006 | 09:37 PM
350SS's Avatar
Thanks!
Old Sep 7, 2006 | 09:04 AM
70 LS1's Avatar
Conversion master
Other way around. The water flows out the top of the water pump into the top of the radiator on the driver's side, then from the bottom on the passenger's side in through the waterneck/thermostat.
Old Sep 7, 2006 | 09:49 AM
Stu Cool's Avatar
Jeff (70 lS1) is correct. Water flows top to bottom.
Pat
Old Sep 8, 2006 | 12:29 AM
350SS's Avatar
I knew it
Gotta love misinformation, thanks guys.
Old Sep 8, 2006 | 06:12 AM
5.3 racer's Avatar
easy way for me to remeber is which hose always blows? the top hose, it's under pressure, where as the bottom has the spring in it because it's under suction.
Old Sep 8, 2006 | 06:38 AM
LS1-450's Avatar
Originally Posted by 350SS
I knew it
My appologies. I was thrown off in that on my Mezier, it is recommended to locate the t-stat on the pump sleeve that connects to the top of the radiator. Thought this meant that the top was the inlet. I too have learned something here. Best wishes
Old Sep 8, 2006 | 08:00 AM
LS1Cobra's Avatar
Ls1450,
You better check to make sure you wired your electric water pump correctly. If not it will flow the other way. I have the electric water pump as well but no T-stat.
Vinh
Old Sep 8, 2006 | 11:51 AM
LS1-450's Avatar
Originally Posted by LS1Cobra
Ls1450,
Vinh
Will do, thanks.
