Mods before dropping in the motor?
Old Oct 6, 2006 | 12:15 PM
heimbo's Avatar
Default Mods before dropping in the motor?
I'm currently bulding an FC LS1 swapper and the motor is just sitting in my garage and I'm contemplating whether or not to upgrade a few things with it before it goes into to the body for the ease of installation factor. I would post this on torquecentral.com but they never verify any of my accounts so it's no use.
Basically I want to put a mild cam in it, valvetrain, ported oil pump, and a pulley.
The only thing that makes me reluctant about the cam is that I'm currently not willing to spend $800 for a set of long tubes.
So..should I do the cam swap, pulley, pump with the motor out because I'm wagering there won't be much room to do the install without the motor at least coming partially out. What do you guys think? anyhelp is much appreciated. what kind of power will I be losing thru the stock exhaust manifolds with one of the 224/224 cams.
Thanks,
Dave
Old Oct 6, 2006 | 12:40 PM
92CamaroReallySlow's Avatar
I did and highly recommend it...way way easier to work on
Old Oct 6, 2006 | 12:46 PM
shifty`'s Avatar
throw in Z06 springs, cam, etc. they can be had cheap, it's a quick couple dozen horses, supposedly very easy to do while engine is out.
Old Oct 6, 2006 | 12:52 PM
heimbo's Avatar
I thought about this, but I think it's too mild for what I eventually want the car to be. It's not some extreme drag car since I've been Autocrossing for the past couple years so like a 224/224 on a 114 should suffice for what I want to do with the car. I'm just not sure how well it will perform on the stock manis.
Old Oct 6, 2006 | 01:39 PM
shifty`'s Avatar
that's cool. just tossing it out there i should have done it to mine before finishing my swap, but ... it's so easy to take the front clip off my truck that it doesn't matter
Old Oct 6, 2006 | 01:56 PM
justanova's Avatar
could always just do the cam and then the headers when money allows.
Old Oct 6, 2006 | 02:19 PM
heimbo's Avatar
I think that's the plan, just don't want the car running like crap because a lack of supporting mods.
Old Oct 6, 2006 | 02:26 PM
pist0lpete's Avatar
I think it should be fine with the cam and stock manifolds or possibly some Z06 manifolds which are cheap and good for a few HP. Although not the optimum setup you would definitely gain alot of power. You would want to retune it after you got the headers but it should definitely be worthwhile.
Old Oct 6, 2006 | 03:25 PM
Andy1's Avatar
I'm using Z06 exhaust manifolds on my '01 LS1 with the logic that they originally supported a 405HP motor. Certainly not as good as long tube headers (though some argue the difference is a lot less than many believe), they are a nice tri-Y shorty design.....and they are way less prone to leakage and much better at managing under hood temperatures. Yup, can be had cheap on Ebay. In the end, it really depends on what you're looking to get out of the motor.
Andy1
Old Oct 6, 2006 | 04:28 PM
heimbo's Avatar
Andy1
I would be all for this, but I just bought some stock exhaust manifolds from an 02 TA not realizing that the Z06 ones were better.
However looking at their design I don't think they will fit in the RX7 engine bay.
Old Oct 6, 2006 | 10:56 PM
OJmobileII's Avatar
i was in the same situation as u. ur doing the right thing by installing things now. i have been told that it is possible to do a cam swap w/ the engine in the FC, but definitely easier when its out.
if ur using stock manifolds, u should choose a cam w/ more exhaust bias. something like a 224/230, .581/.592 111+1 XE-R was suggested to me by a mod in the internal section.
Old Oct 6, 2006 | 11:57 PM
cws T/A's Avatar
put in some katech upgrade rod bolts while its out
