Another LS14 Project.
Old Nov 20, 2006 | 07:57 PM
  #101
Ted J's Avatar
Also, if the camshaft is original and you can read the P/N on it, don't know if you can or not, the F-bodies cams go as follows:
'98 - 12557812
'99-'00 - 12560965
'01-'02 - 12561721
HTH!
Old Nov 20, 2006 | 07:59 PM
  #102
Ted J's Avatar
Once you pull the rear main cover off you should be able to also see the rear oil passages. Since the casting number shows it to be a later block instead of having two smaller type holes the oil passeges should be pretty open all the way across the top of where the camshaft is.
Old Nov 20, 2006 | 08:17 PM
  #103
datboibrad's Avatar
welp a picture is worth a thousand words
Old Nov 20, 2006 | 08:18 PM
  #104
datboibrad's Avatar
how is it that an 01 can run with a 98 ecu???
Old Nov 20, 2006 | 11:47 PM
  #105
Slo_240sx's Avatar
It cant. Your numbers are wrong or they mixed the computers. The 98 is the only year that looks different. It is huge and has cooling fins. If it has no fins and is more FLAT then its 99-02.
Old Nov 20, 2006 | 11:48 PM
  #106
datboibrad's Avatar
nope its huge with fins brah
Old Nov 20, 2006 | 11:57 PM
  #107
datboibrad's Avatar
Old Nov 22, 2006 | 02:40 PM
  #108
datboibrad's Avatar
Progress for the day. 25 dollar motor mounts :] im going to do what chin did on the bottom half with just a solid brick of alum which is really cheap so total like 50-60 for front mounts i can live with that. the eventual design of the mounts will be a lil different but essentially the same with no difference in cost so thats a +
Old Nov 23, 2006 | 02:32 PM
  #109
mikespeed95's Avatar
alante
Old Nov 23, 2006 | 11:10 PM
  #110
mmdb's Avatar
Are you going to fab up your motor mounts? If so I'd be intrested in picking up another pair from you. Just name your price. Also let me know if you're going to make the transmission mount, or any other parts (driveshaft) and I'll pick those up from you too!
Old Nov 24, 2006 | 12:18 AM
  #111
datboibrad's Avatar
lol they are fabbed. ill be making all my mounts. a driveshaft is something i wouldnt attempt myself due to balance issues. the motor mounts still need another peice that will bolt to the frame, but its essentially just a solid block with 2 holes drill in it. total engine mounts shouldnt cost more than like 60 bux. im trying to fab a mounting kit for roughly 100 bux total.
the mounts themselves are nothing but flat plates drilled out and 1967 Chevy El Camino (as well as millions of other GM cars) mounts. got them for like 5 bux a peice from my job (Autozone) with a lifetime warranty lol
Old Nov 24, 2006 | 10:45 PM
  #112
when you need a drive shaft let me know ill hook you up on drive shaft shop unit.
Old Nov 25, 2006 | 02:35 AM
  #113
datboibrad's Avatar
**** fool ill buy it right now. just curious though if its the same distance tho. im going to atleast wait until i get my oil pan in to make my tranny mount then ill know the correct length.
Old Nov 25, 2006 | 02:06 PM
  #114
just send me measurements and ill get you one made
yours shoudl be aruond 2'' longer than mine, but thats only because your black
Old Nov 25, 2006 | 06:52 PM
  #115
datboibrad's Avatar
i tell you what man. that MS4 with a 150 shot is going to keep me with a boner for a goooood while
Old Nov 28, 2006 | 07:40 PM
  #116
the.erinyes's Avatar
Man, you gotta get out more!
Old Nov 28, 2006 | 07:42 PM
  #117
Chin180sx's Avatar
MS4 is keeping me perfectly happy.
Old Nov 28, 2006 | 10:54 PM
  #118
datboibrad's Avatar
between 12 hours class schedule and 40+ hours a week at autozone i dont have time to get out lol
Old Nov 29, 2006 | 04:06 PM
  #119
datboibrad's Avatar
not much of an update, but for the price tag on these im most certainly going to post a picture of them hahaha
Old Dec 10, 2006 | 12:12 AM
  #120
datboibrad's Avatar
figured i would add more pics since all ive done in the past 2 weeks is buy **** and wait for it to come in lol.
This is what you get after spending 300 bux on aluminum : \ lol
Mounted up the GTO oil pan. something i did notice is the difference in coverage of the windage trays vs the f body tray. it covers 100% of the main cap area vs the f body trays 70%.
i sneeked in a picture of my freinds early christmas present. complete 00 ls long block
