LS1 into kit car- carb sizing query?
UK based.
I'm going to install a standard Ls1 into a kit car (Gardner Douglas T70 replica lola) and run it on a carb, using the edelbrock /msd conversion plug n play into the stock coilpacks/cam/crank sensors.
the question i need to answer if possible is what is a suitable carb size for my application? i need a manual choke, and the car is going to be used on track and for sprinting, maybe a few drag runs, but very little road use. i dont want it to be a pig to drive though!
the engine will have race type headers and a simple race type exhaust, quite free flowing.
initially i am sticking with a standard engine and heads/cam, as the car will only weigh around 900kg.
i sent this question to edelbrocks tech helpline and was given advice to use a 800cfm (electric choke!) carb, which doesnt look to be right?
I'm not sure what power to expect out of a stock ls1 on carb set up with decent headers/exhaust, but dont want to strangle it/oversize it with the wrong carb. I may in the future get a mild cam but leave the std heads on, so something with a little "headroom" for tweaking further might be best?
Also, anything to choose between say Holley or Edelbrock carbs in whatever size is recommended?
thanks in advance
chris
i wouldnt go 800, IMO unless you need all out top end power. with stock cubes, the bigger carb will hurt you low and midrange.
750 max, but thats just me.
contact any carb shop and they can get whats right for your application.
good luck!
one question i also have is mechanical or vacuum secondary's? for a track based /lightweight car would mechanical be better?
cheers
cheers
the carter clan will tell you that holley is junk and vise versa, but you may run into those problems with the carter style carb.
on a holley, you can lower the fuel bowl a bit and loop the vent tube to keep fuel from sloshing from the bowls. if you have a good fuel pump, you wont have to worry.
might have to adjust the idle or the transition circuit since there is less pressure forcing down on the orfices with the low fuel in the bowl.
might lean things out in a spot.
if i had a lightweight car, going around corners, i might want a vacuum secondary to pull the power in slowly not to shock the tires in a corner.
with decent power, a mechanical carb "hits" the power in a hurry once you put your foot in it.
those few tenth of a second delays may be enough to keep the tires planted.
its just a guess, but it sounds like a decent one.
there are adjustable diaphrams out there too, so you can bring the rear in sooner or later than your old school style secondary carb.
bill is right, matt runs a 650, but it is worked a lil bit. his is an AED performance eliminator carb, and he says its the best one he has ever owned.(and he has had many carbs, i can tell you)
good luck!
My 2 cents..
I'd vote for the Holley, as many more mod's can be done to tune for your type racing.
For a stock engine.. try going with the 650 with Vacuum and then move up to a 750 if that doesn't work out or if your are looking for more. (I think that is were you will end up)
I think GMPP is marketing a LS1 Crate with there Carb mainfold and carb, You might want to look into this to see what HP rating and carb size.. maybe that will give you a good start.
A engine with a more open exhaust system as yours will run leaner than one with a stock system or smog'd down and you can get away with a larger carb.
I once ran my 57 Chevy with a 283cid and a 850 Double pumper.. that seem like over kill to most.. but I was running 4.88:1 rear gears and a 4sp. And it did come on at the top end great and was still liveable on the streets (but gas was 27 cent a gal for super then, yeah... giving away my age) !.. so, it depends !
I'll be running a porsche G50 box (already have that) and a custom bellhousing adaptor to mate to the LS1.
reason for running carb is that its a replica of a 1965 Lola T70 spyder and i'd like authenticity to some degree, altho the originals ran weber carbs and trumpets i believe. I've also never had a big carb'd V8 and always wanted to play with one, current road car is jap turbo 4wd with a mappable ecu so this will be a change!
Holley 505- can i ask you a question, how did you find the rpm/msd kit worked on your install? is it a proper plug n play conversion as it looks?
cheers
chris-m - I would not run the msd box that edelborck includes due to it's limited capabilities (plug in timing chips).. Go with the MSD-6010 box that includes the pro-data+ software.. just my .02 and it's almost the same price seperate..
cheers
Sure it works. But the new kit will work better with the software i am sure. You only get 6 pills. So with the new setup, you will be able to squeeze a few more ponies out of it.
BUT the base kit has good drivability and road manners... good power... no issues here. But if you want to MAX it out... get the new kit or RUN SOME NO-2...new KIT !!
Vcious04 you make a good point, but
the base Kit works... and it comes with the manifold so you get a little savings... if you don't have the LAPTOP or SAVY to program it ? It could be a pain in the A$$ not to mention costs a little bit more.
Of course they have a hand held programmer also...
MO MONEY .... MO MONEY ....
plug it in the side of the box and program timing, 2 step and reatard.
from what i understand, it works like a SCT tuner.
TJ got any pics of your IROC-z ??
oops....
I am a sucker for 3rd gens.
check my old ride.
