LQ9 accesories compared to LS1
C5 & trucks run the alternator up top (way up top) where it is very visible. Power steering pump is below that (not very visible). Placement of the alternator makes it very easy to service, but also means you might be concerned in what it looks like.
The F-body access place the alternator way down low, almost next to the crankshaft, with the powersteering pump above it. Depending upon your application, the alternator may try to occupy space that something else should be in. For example, in an S10, the f-body alternator and the truck steering box want the same space. In my case, the steering box won, I run C5 access because of location of the alternator (and space, need more space).
I would expect the truck access to be the least expensive. The C5 stuff is probably the most expensive. F-body should be somewhere in between. Be warned that not a whole lot interchanges, even stuff that looks like it should, like alternators. I found out the hard way that the truck alternator doesn't fit on the C5 bracket. The pulley is in the correct spot, but the 2 mounting holes don't line up (pattern is about 1/2" different). Ended up having to make and adapter bracket.
'JustDreamin'
The C5 / C6 / CTS-V accessories are the shortest and typically most expensive, but also are the closest to the block (most radiator / fan clearance).
The next step out (less radiator / fan clearance) is the F-body & GTO, by like 3/4".
The furthest out is the truck package. They're like 2" further out than the C5 or F-body stuff (not an exact measurement).
Hope that helps....
'JustDreamin'
