My LS1 RX7 Build
Old Apr 22, 2007 | 10:19 PM
  #101
Sabre002's Avatar
yea I got the headers from JRT Jags that run. My car will weigh in at 2800.
ok this is my update for this weekend, its a good one.
Started off Friday night took the drivers side header off to clearance the trans tunnel (beat it with a hammer) it did not take much but it had to be done. Then we went to bleed the clutch. I don't see what everyone has had so much trouble with, here is how I did it. I would bleed the master for about 5 mins with some help, then when I got all the air out of it I would bleed it, with my friend keeping the petal to the floor I would let all the air get out of the line I had on the bleeder then he would slowly pull the petal back sucking all the fluid back into the line then I would close the bleeder. After repeating this a few times I just let the slave gravity bread for about 3-5 mins, and went back to get a little air out of the master. All worked great but I remembered that GM said some might have to sit for some time to allow the air to rise to the top so I re bleed it the next morning and just got a little more air and full petal.
Now the fun part I started the wiring. one thing I must say is that it would be nice if the location to the connectors and places to look for wires need a little more detail in them lucky I have a factory manual but for someone with out one good luck. I started with the constant and switch power to the LS1 ECM simple all under the dash on the passenger side, got the damn EL box out of the car to run the check engine light let me let you with the blower motor in the way and the fact that I had two in there because someone replaced one and never removed the old one it was a bitch getting that old connector off. Next I made my way to doing the fuel pump here is the link to my wiring troubles with this. http://www.v8rx7forum.com/v8-rx7-tec...-shooting.html If anyone has a clue let me know but I think I will get back on track next weekend.
Finally we got the tank in with all the lines run. New SB line for the supply and reused the factor hard line for the return I cut out the factory clips to make then able to hold the lager -6 line and it worked great the plastic tray had to be trimmed a little cause it was on the header but it is still there doing its job.
Until next weekend.
Old Apr 23, 2007 | 07:45 AM
  #102
pearceleather's Avatar
Man it's a pain reading all those threads. Too much info and to much mis-information.
In short just throw a realay in there.
You'll need for wires:
Trigger coming from either the computer or just a switched source
12v constant
ground
12v output to pump.
Just make it nice and simple. Not only will it work, but diagnosing probelms gets a lot easier.
Old Apr 23, 2007 | 08:35 AM
  #103
Rodder's Avatar
12v constant
ground
12v output to pump.
DON'T JUST USE A SWITCHED SOURCE FOR THE FUEL PUMP!
Any time you run an electric pump, you need to also run something that'll cut power to the pump when the engine dies. In the event of an accident, you don't want something spraying fuel at 255lph! Trigger the relay off the computer. It's not hard.
Old Apr 23, 2007 | 12:34 PM
  #104
Sabre002's Avatar
That is the way I'm doing it. LS1 ECM will control the fuel pump with the factory wiring and relays that are already there. I dont like adding **** just to cut the old stuff out.
Old Apr 23, 2007 | 12:50 PM
  #105
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by Sabre002
Got some parts here this week, so I will see what I can get done but I dont think I will get much done here this weekend I got so many other things going on.
Which headers are those?
Old Apr 23, 2007 | 06:42 PM
  #106
Sabre002's Avatar
They are JTR 1 7/8 long tubes.
Old Apr 23, 2007 | 07:33 PM
  #107
Proof that I am not the smartest person in the world, damn!
Seriously, good point, I never thought about that.
Old Apr 25, 2007 | 09:05 PM
  #108
Sabre002's Avatar
yea its ok man, Im going to get it all figured out this weekend so maybe I will have a startup vid
Old May 1, 2007 | 07:09 PM
  #109
Sabre002's Avatar
ok here is what everyone has been waiting for I got it running this weekend and here is a starup vid for you guys I hope ya like it. This is open TB and no MAF so it hunts for a idle for a sec, but I have to say its not to bad.
Click here to see Video
Old May 1, 2007 | 07:34 PM
  #110
the.erinyes's Avatar
Sweet! Really nice job.
Old May 1, 2007 | 07:51 PM
  #111
Reject's Avatar
hehehehehe!!!!
aaw it sounded like my rotary at first then ls1 lol
Old May 1, 2007 | 08:28 PM
  #112
LSGUNSS's Avatar
formerly 2000blackcamaross (6-25-2013)
Your my new hero. nuff said.
Old May 1, 2007 | 08:34 PM
  #113
Sabre002's Avatar
yea its got 8 bad Apex seals hahah.
Thanks guys
Old May 6, 2007 | 01:13 PM
  #114
ITSA6's Avatar
just read this whole thread very nice job very impressive
Old May 6, 2007 | 08:28 PM
  #115
GTOpowered240sx's Avatar
Nice build up! Makes me want to go buy a beadblaster.
What cam is that?
Old May 6, 2007 | 08:40 PM
  #116
67maro's Avatar
That thing is crazy and if I had money Id build one. Are you gonna paint it or leave it that color.
Old May 6, 2007 | 09:03 PM
  #117
Sabre002's Avatar
Its a custom comp grind. .589/.589 236/236 112 LSA
Yes it is going to get painted PPG jet black, I'm building a motor for a friend who it a painter and he is going to take care of my car. That beadblaster is the best tool in that garage haha.
Old May 7, 2007 | 02:55 AM
  #118
Dragframe's Avatar
so how hard is this swap? i seriously want one of these cars.... tho im not sure how cheaply i will be able to find one... they are pricy...
Old May 7, 2007 | 08:45 AM
  #119
digitalsolo's Avatar
Two competent people can do this swap in a weekend or two, first time around. I've done several of these cars, with good result, and, although I know my way around a wrench, I'm far from a professional mechanic or fabricator.
Old May 7, 2007 | 08:10 PM
  #120
Sabre002's Avatar
I dont know about a weekend or so not the way I am about doing things, plus it would have to be a perfect roller ready to go witch I did not have. Its not that hard really I have welded one thing on the trans mount and bent the lip on the fire wall along with hammering the tunnel other then that it bolts in right nice. I have other plans for fabing up some rear end mounts but that it not really required for a street car.
