Taurus 2 speed cooling fan
Anyhow, as for your question, of the three wires coming off the fan, the black one is ground, and the orange striped is one speed and the yellow striped is the other speed. (I can't remember which is which) To find out which is which, touch the black wire to the negative terminal of a battery and one of the other wires to the positive. Then with the black still on the negative terminal of the battery, touch the other striped (only one at a time) to the positive. The speed difference will be apparent. I have the low speed relay hooked to the low speed side and the high speed relay hooked to the high side on my car like you are talking about and it works great. The low speed moves enough air that the PCM has never called for high speed yet.
Just to be clear, you can't wire this fan up exactly like the dual Camaro fans are wired, which is kind of a series connection to produce a low speed. The Taurus fan simply uses one relay for low speed and one for high speed, with only one speed powered at a time. This is important. If both speeds are powered at the same time, the fan will just fight itself and burn up. There is a low speed fan output from the PCM and a high speed output. Just wire each to the respective fan speed relay and you are set.
G-body is right. When high speed is called for, both PCM outputs actuate all three relays in stock F-body form. I guess its a good thing my car has never called for high speed.....
You can still use low and high speed though. It would require a third relay. The ground wire of the low speed relay going through the N/C contact of the third relay, with the third relay being acutated in parallel with the high speed relay. That way, the low speed relay would release when the high speed is called for.
Or, if you don't want to go through all that trouble, you could just use one speed. Like I said above, the low speed keeps my LT1 Cutlass cool even in summer with the A/C on.
Guess I have a little rework to do on my daily driver.
Hope I didn`t confuse anyone with my diagram above.
http://order.waytekwire.com/IMAGES/M...og/219_059.PDF
