AC system on 98 Ls1 swap
Old Nov 30, 2006 | 08:13 AM
Tiago's Avatar
Default AC system on 98 Ls1 swap
Anybody have the AC wiring figured out on a 98 LS1?
I just finished my swap, fired right up, damn I was edgy for a bit, lots of wires but in all the FAQ's and searches I did people disregard the AC system all together.
I have a plug that goes into the cabin that was not used at all, I assume it has something to do with AC.
thanks,
Old Nov 30, 2006 | 08:38 AM
Brains's Avatar
That's going to be the A/C request wire more than likely. Hook it to a switch to request the PCM to turn on the compressor.
Yours shouldn't be too terribly tough, I hacked and whacked an entire LS1 A/C system into a Mustang - fiberglassing up the heater box under the dash and everything
Old Nov 30, 2006 | 03:51 PM
Tiago's Avatar
its more then one wire its like 6 of them on this one conenctor, its the only connector not adressed in all the wiring diagrams/pinout diagrams in the FAQ.
Old Nov 30, 2006 | 08:25 PM
Brains's Avatar
There should be three connectors going inside the car. The blue connector is the one that has the A/C request wire, and its the green wire on that blue connector. Those three connectors are full of useful stuff - park/neutral switch, brake pedal switch, VSS, serial data, SES light wire, etc. I mapped out the ones relevant to my conversion so I can help you with at least those if you need 'em.
Old Dec 1, 2006 | 07:37 AM
Tiago's Avatar
I got those all hooked up
but I have 4 connectors going inside the three standard ones I have hooked up and there was a 4th which I thought was additional AC stuff. I'll have to snap a pic.
thanks,
Old Dec 1, 2006 | 08:22 AM
Brains's Avatar
Its a 98 LS1 engine harness?? Yeah, snap a pic and I'll see if it matches mine. If nothing else, just backtrace the wire from the PCM.
Old Dec 1, 2006 | 07:37 PM
Tiago's Avatar
here is a shitty pic but you get the idea, the three normal connectors are to the right, the one taped to the left is the left over one.
Old Dec 2, 2006 | 06:35 AM
rao's Avatar
rao
Me. I posted how I did it on the torquecentral.com rx-7 swap forum. It is not hard, but there are a number of wires taht need to be addressed. The hardest part is finding the correct fitting for the LS1's refregerant pressure sensor, and I posted about that on this forum.
