Picked up my motor set tonight.
Picked the coldest night of the year so far to drive the F250 out to Elgin and scooped up my motor set.
Got a 98 LS1 out of a Camaro with 70K miles on it. Also got the A4 trans, wire harness, ECU, MAF and Hypertech programmer. Its missing a PS pump but other than that, it looks complete. I got the alternator and AC compressor in a box along with a box of bolts.
Going into a '90 240sx fastback.
![](http://i110.photobucket.com/albums/n86/bullitz400/DSC01097.jpg)
![](http://i110.photobucket.com/albums/n86/bullitz400/DSC01098.jpg)
I guess it all depends on what HP Output and usage you are planning for the 98 LS1.. but no reason why it can be a good runner and have some mod to it and still hold together.. There are some problem with them.. but as you see, them 98 are still out there and running, so.. depending on what your plans are.. have fun !
Originally Posted by firefighter
are you gonna go through that motor? time for some fun.
Originally Posted by Chin180sx
Looks clean. Are you going to keep the tranny? They say the 98 motor isnt as good as the 99 and up. But aslong as you have the 98 ECU and wiring harness you should be ok.
Originally Posted by mullenh
Eglin? AFB? If so well hey neighbor. But as for cold, lol, you left out that you are in florida.
Good luck
Good luck
Elgin IL. Suburb of Chicago.
Originally Posted by 9sec240
HAHAHA.. no... its been a while since I have been to an AFB... I got out of the Air Force in 90 so thats 17 years ago.
![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
Originally Posted by Kidd597
The fastback...is that the hatch if so we have the same project going on...ls1 into 90 s13 hatch...How did u find the engine in elgin??
I actually found the motor on chitownracing and found the same motor listed on ebay where I bought it.
If you are gonna pull the pan and check some rod bearings you at minimum need to put some upgraded rod ARP bolts. Hell just throw some bearings and if you get crazy put some pistons, just so you don't have to worry later. It'll add minimal cost (less than a grand) and will give you insane amounts of peace of mind especially if you are gonna spray it.
Originally Posted by nycab
wanna sell the f-body oilpan? ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I have yet to pull the pan but I would assume that the oil pickup needs to be changed to fit the GTO pan..... unless for some reason it swaps to the other end of the motor???? But yes, I would be willing to sell the pan, pickup, windage tray, dipstick, etc (not sure what all needs to be swapped) for whatever it costs to pick up the GTO pan and accessories I need.
