Tensioner Pulley Location
Where would the best place to locate a tensioner pulley for this set-up? I was thinking either to use a vette pulley to the right of the ac compressor or put a pulley to the right of the alternator and above the power steering pump. If I put it by the alternator, is the distance between the ac compressor to large and will it cauce the belt to jump off the water pump pulley? What are some of the aftermarket companies that make different tensioner pulleys? I am planning to make the brackets out of 1/2" aluminum plates and aluminum spacers.
You may need an additional idler pulley to pull the belt around the water pump a little further and allow the tensioner to apply tension without making the top and bottom touch (which would be bad).
Just my thoughts....Keep us posted as to what you figure out. I need to make a custom high AC mount for my truck (using C5 access) sometime between now and summer, and its always good to know of potential pitfalls before falling.
'JustDreamin'
I was looking at the S&P catalog (LS1 high mount alt & ac on page 78). Do their idler pulleys take up the slack or do you have to adjust the rods on the alt and ac to tighten the belt? It doesn't look like there is enough room for the idler arm to rotate.
Andy1
Does anyone have dimensions for the mounting holes on the heads and waterpump relative to their assembled positions and the the crank and water pump pulleys? I tried to measure them with the engine in the car but it was hard to get accurate measurements. I am trying to make a cad file to find the best place to mount the tensioner pulley.
I went through similar pains to re-arrange my serpentine routiing. Looking at your illustration, a couple of thoughts come to mind. If you used the FBody alt bracket and idler, and FBody PS pump, then that would efffectively switch their positions. The alt. would be where your PS pump is, and vise-versa. With that, you would gain and idler which would provide increased contact with the crank pulley, yet retain the same basic routing that you have. You''ll just need to add the tensioner somewhere.
Another thing you can try and perhaps with less effort, is to route the belt from the right side of the crank pulley (anti-clockwise), then up and over the WP, then down to the PS pump, the up to the alt, over to the AC, and so on. That way you'd gain increased crank pulley contact without changing the brackets. With this, you could put the tensioner in the stock position and simply replace its pulley with a smooth one (since you'll be running now on the back side of the belt)......... Did you follow that??
Andy1
I am also looking for the dimensions for the mounting holes in the head from one side to the other and to the waterpump. Also for the belt tensioner to the pass. side front mounting holes in the head.
I have no idea what the general rule is. I suspect the more accessories (load), the more contact the crank pulley requires. What crank pulley are you planning on? I switched to an LS6 Vette because it's shorter, but the down side was it moved the AC belt quite a bit closer to the motor.
Thanks for the Dayco tip. Is there a better way to look through their tensioners, or do you have to search through by application only?
Below, is a photo of what I did for my LS1 914 conversion. If I can find a different tensioner on the Dayco site, I'd like to shift my tensioner pulley to the left (to gain a little more contact with the WP pulley). If it is simply a left hand version of the stock type tensioner, then that would be good.
I know you asked for the mounting hole centers, but my motor is temporarily installed at the moment, so I can't measure it.
Andy1
I should have measured the motor before I installed it. If that setup is working then the one I am looking at should be fine. The dayco site has a 23 page pdf document with pictures of all of their tensioners and pulleys. I called the auto parts store with the dayco numbers and found the vehicle application. If you send an email to dayco they will send a supplier drawing with relative dimensions of the tensioners. The 89254 tensioner with 2 pulleys may work in that location on your motor too. If you send me some dimensions to locate the axis of the compressor to the w.p. and crank axis I can place the tensioner in there for you like I did in the picture above.
Thanks
Pat
If you compare to the GM setups, they've got alot more wrap and aren't driving the AC compressor (so have less load).
Don't know that I've been of any help here, but that's my thoughts
'JustDreamin'
Thanks
I had to move the AC compressor back about 1" to align with the LS6 dampener, then down about 1 1/4" in order to clear my Z06 exhaust manifold. Luckily, the 4 rib Vette AC belt is 1" longer than the FBody one, so that worked out great.
Andy1
