Need some help with my LS1 Fueltank...
One of these two marked fittings has to go, to make place for my fuelfiller tube.
can you guys telle what number 1 and number 2 are and what they do?
THANKS
Peter
#2 I have no idea, I`ve never actually worked on a 4th gen camaro. Do you know what it used to connect too?
After some search I found out number 1 is evap and the other, number 2, is connected to a lose hose, which is pointing down.
Is the number 1 enhough for venting the tank? I could add a screw in overpressure valve from a boat tank somewhere.
Or can I better leave the evap out?
Please help...
Peter
One needs to go!
If its a choice between one or the other, ditch the stock vent, it has to be easy to make a new one somewhere else that fits in your plans.
