ls1 mustang track times
Originally Posted by CMcCarthy
Why even bother taking a Mustang to the track on 20s?
Put some 15" draglites and any ol' sticky tire on it, and your ETs will absolutely plummet.
i got some prostars with slicks,and we'll see what it got sunday
With that kinda MPH turning those heavy assed 20s, I'll predict 6.90s at about 100.
My buddy has a Lightning with 22s, and it's 8 tenths slower in the 1/8 mile with those versus the stock 18s.
I have to get a bigger tire on mine but it went 10.4@131 and it started hitting the rev limiter a couple hundred feet short of the finish line. That was with an MS3 cam, 3.55 gears, long tubes, 3800 stall, 125 shot and a TH400. On motor it went 11.2@125 1.8 60' with 7 degrees taken off the timing for the nitrous and 26" 275/40/17 drag radials. I am switching to 28" 275/60/15 drag radials to allow for more MPH and will be upping the shot some to get into the 9s. The car went 6.6@109 in the 1/8 with the 125 shot on a 1.5 60' which should go down to a 1.3 or so on the new tires and launching on the spray. Oh the car only dynoed at 320 on motor/430 on the spray at 2820 lbs. without driver so obviously the trans/converter combo is hiding some power on the dyno and I have some weight to shed. I still have some bugs to work out too and its only got a few passes on it but it will be fun when its all worked out!!!Actually its fun like it is
i took mine out to a local gtg,and i ran a friend that has a t/a that runs 7.2 @96. we ran fom 30 to 100,and i put 4 or 5 cars on him,after i stoped spinning(he has d/r's).we are both stalled auto's,he has 3.42,i hav 4.30 ,so mines a lot better fom a dig not this "from a roll" $hit
i'm going to the track sunday with slicks so i'll post my times when i get home
the track i'm going to sunday isn't known for having accurate times,it's more of a outtlaw "money race" typ of place.but it should give me a idea of what it will do till the real track opens january 19
Awww, the getto track! Just don't shoot anyone there!!!
Talked to Lloyd today he said that thing is running like an ANIMAL. I'm sure you'll be in the 6's with some traction.
Bret
Is that cam only no heads? Is your FI or carbed. How is your ignition curve set up?
Its just a cam w/ fuel injection and a baseline tune nothing spectacular. I had a 125 shot on it when it ran the 10.4 pass but should be a 10.1 or so once I get the tire situation worked out. I also plan on increasing the shot to get into the 9s like I said and will post some pictures once the car gets back from paint.
Originally Posted by SStrokerAce
Beau,
Bret
Bret
the cam makes bad *** torque,it pulls just as hard at 3,000rp's as it does at 6,000rpm's and it pulls to 6,700rpm's
How the heck does it run like that LOL. What should i expect out of my 2800lb car with 3.73, engine stock, with long tubes,victor jr 750 carb, 3200-3600 stall.
i say with some sticky tires it should go mid to high 11's
#32
thanks,bret
Bret
#33
why even have 20's on a mustang??? 20s should be on 87 crown vic or a full size truck. not a notchback. in my opinion.
#35
let me gess,you think all mustangs should have cobra wheels
#36
I'm of the same opinion as vanilla89. I'm tired of seeing every fox mustang out there with cobra R wheels on it. The problem I've found is the fact almost nobody makes an equivalent sized wheel (18" x 9") with the correct offset that the car needs. The offsets are really goofy to make that wide of a wheel work. I've been digging in import magazines just to try and find someone that makes the right offset, but with mostly bad luck. The search continues . . .
#38
we were at the track,and my friends were like"take that thing down the track" so after 20min's of that,i did
Well what did it do.
#39
rt .0569
60ft 1.64
mph 95
et 7.32
and i let out 30yrds befor the finish line
it still spins real bad,but i'm goin to adjust some of the suspension and let some more air out of the tires(they had 15psi this time)
60ft 1.64
mph 95
et 7.32
