ODB2 port problem?
Old Dec 19, 2006 | 07:27 PM
Tiago's Avatar
Default ODB2 port problem?
I have just finished a swap of a 98 LS1 into my 94 firebird. Car runs great, but I can't get HPTuners to connect to the PCM through the ODB2 port. I wired it up by this diagram and have tripple checkeed all four wires, the 12+ is live all the time, not switched, grounds are good and the serial data has been tested back to the PCM and it is correct. Yet when I try to read the PCM it says to check and make sure the key is on teh on position and the cable is connected? WTF?
Old Dec 19, 2006 | 07:32 PM
G-Body's Avatar
sawzall wielding director
The 98s are different, they have 2 serial data wires. Let me see if I can dig up a diagram.
Old Dec 19, 2006 | 07:33 PM
Tiago's Avatar
I have the second one hooked up too, it goes to the # 9 port.
Old Dec 19, 2006 | 07:36 PM
G-Body's Avatar
Hmmm, I can`t think of what would cause that.
Old Dec 20, 2006 | 07:25 AM
Tiago's Avatar
BTW for reference though, the #9 port is not even used on the HPTuners cable. There is no prong on the connector there......
I know the cable works on my 99 and several other 99-02 cars, I wanna say its been tested on a 98 too before
Old Dec 20, 2006 | 04:47 PM
Tiago's Avatar
confirmeed it works on other 98s......
Old Dec 20, 2006 | 05:56 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Then you have to figure out what is wired wrong. The grounds and power are easy, so double check that pin 2 of the ALDL is going to PCM BLUE 58. That's the Class 2 serial data. Make sure you didn't get mixed up with the UART serial data line that goes to PCM BLUE 3. That isn't needed at all.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Dec 21, 2006 | 07:35 AM
Tiago's Avatar
I have confirmed this already. Are the grounds supposed to go to any specific pin on the PCM or any ground is good enough?
Old Dec 21, 2006 | 10:27 AM
G-Body's Avatar
Technically the grounds are supposed to be run separately, but I have seen a lot of people just tie them together directly behind the port and then run a single ground without any problems(me included). They can be grounded to anywhere there is a grounded piece of metal. I tied mine into the dashboard ground, but if your having problems mabey try grounding them to the same place that you grounded all your computer grounds.
Old Dec 21, 2006 | 10:39 AM
Tiago's Avatar
I tried them together and seperate, I know the grounds are good Ive tested them
can a bad PCM do something like this?
Old Dec 23, 2006 | 05:34 PM
Tiago's Avatar
TTTtrhrf
