Can a driveshaft be lenghtened ?
I have the ls1 camaro DS sitting at home but it's too short. I'm wondering if it could be used...
So is it worth it for me to hang onto it ?
Would they still need the ends ?
So they can make it longer by replacing the tube... And keep the OEM ends..
How much should that run me ?
Any reputable shop I can ship it to to get this done ?
What happens at the driveshafts critical speed is that it is stressed too much, and bends, it starts to whip around like a jump rope, shortens and pulls out of the back of the trans, rotates back under the rear wheels and either the u-joint/yolk breaks and sends the driveshaft flying behind the car or the rearend could rip out from under the car.
Interesting sidenote
Critical speed on the new chevy 5.3L avalanches is between 100 and 120(can`t remember exactly), I forget which aftermarket company found that out the hard way on their dyno
I ordered a shaft, circa 53" long, 3" chromoly steel for my car, from a big name supplier.
Not once was critical speed ever mentioned to me, and this cause me no end of hassle. IMO it was an utter disgrace of any such company not to inform the purchaser of such an important thing when placing the order..
I installed the shaft, and car was driving fine....until I got around 120-125mph, then an almighty vibration entered the car.
I took this to mean the shaft wasnt balanced properly. I had it checked locally, and they said it was fine ( they werent aware of this term either, although they mostly do truck etc )
I re-fitted, and the same crap happened.
I got them to re-check and balance it again....still the same. Only then did I start asking, and learn about this critical speed issue.
At the same time, I was lucky, my shaft didnt fail.
The best analogy I can give, is try and spin a flag pole, and you can imagine what will happen. It will eventually flex and vibrate itself apart.
I ended up with a custom 2 piece shaft, that so far Im have taken safely to over 8000rpm.
The 1 piece could barely go above 5500rpm.
Carbon and Alloy shafts will have a higher critical speed, as will larger diameter shafts. These werent an option for me though. The 2 piece assuming it will withstand the power/torque, is perfect for my car.
So far so good.
