Pics of the ol "ROCK"
Old Dec 28, 2006 | 10:25 PM
6L.IROC-Z's Avatar
Originally Posted by Doughdog
Did you use the truck oil pan? Or did you swap for the ls1 pan? Was the converter custom to work with the lsx motor, or could a stock converter be used?
Thanks
I used the f-body pan,the converter was the easiest part of the hole project.I picked up the phone,called The Converter Shop (TCS)928-453-4020 asked for Rusty, told him my motor,trans and what stall i wanted.$450 dollars and three days later I had a badass converter on my front step.
Old Dec 29, 2006 | 03:37 AM
92zcamaroperson's Avatar
hmm....well then...that sounds a lot better to me than some adapter
Old Dec 29, 2006 | 04:50 PM
Doughdog's Avatar
Thanks for the info guys. I thought I'd add if someone was going to use a stock converter. I have been serching, and I think MABY you can use the 4l60e converter in the 700r4 and not use an adaptor. I am not 100% on that one though.
Old Dec 29, 2006 | 05:27 PM
StngKlr's Avatar
Good job on the swap.
What size DR you got back there? I'm waiting on my 10-Bolt to blow too, but it seems to be doing good so far. Its been sprayed on a few times too.
Old Dec 30, 2006 | 11:51 AM
6L.IROC-Z's Avatar
They are 275/50r15. Ive done a couple launches on the street and I think it will be ok but at the track and a 150 shot is where the problem will be.
Old Dec 30, 2006 | 01:25 PM
StngKlr's Avatar
I'll be running the same tire next year with a 150 shot also. I have used some 275/40/17's at the track and they worked great, but that was on motor. We'll see how it goes this year.
Old Jan 1, 2007 | 09:06 PM
6L.IROC-Z's Avatar
Are you guys running a heater? If so what did you do for the connection at the fire wall, with my setup the heater core inlet/outlet are right behind the head and valve cover . The only thing I can come up with is getting some 90* pre bent rubber hose like a rad hose but the correct size.I think reg straight hose will kink in that tight of a radius.
Old Jan 1, 2007 | 09:09 PM
LS1-IROC's Avatar
You are in luck....I just bought some heater hoses today with pre-formed 90's on the end...I'll get you the part numbers from the hoses tomorrow.
Old Jan 2, 2007 | 05:56 PM
LS1-IROC's Avatar
Okay...I got these at Carquest and they are made by Gates
28470......5/8 heater hose....$12.97
28480......3/4 heater hose....$19.48
The 5/8 hose is about a foot short so you will need to splice it...the 3/4 hose is plenty long enough. These hoses have a 90 degree bend molded into them at one end.
Old Jan 2, 2007 | 06:57 PM
Roller406Bu's Avatar
Bad *** looking 3rd gen, I love it...Props to you for the swap, wish mine was done...
Old Jan 2, 2007 | 09:02 PM
jlrz28's Avatar
10 Second Fun Car
Any videos of it running? Looks like a nice swap!!
Old Jan 3, 2007 | 02:24 PM
  #32
6L.IROC-Z's Avatar
roller406bu I love that maibu. jlrz28 i will try to get a vid up
Old Jan 3, 2007 | 07:17 PM
  #33
6L.IROC-Z's Avatar
ls1-iroc thanks for the part # but i found out a 28471 is a foot or so longer than the 28470 so you dont need to splice. thanks again for the #
Old Jan 3, 2007 | 07:26 PM
  #34
LS1-IROC's Avatar
Ahh...good tip! They must of not had that one in stock when I went looking....
Old Jan 3, 2007 | 08:28 PM
  #35
PRAY HRD's Avatar
2nd on the vid man!
Old Feb 4, 2007 | 09:58 PM
  #36
6L.IROC-Z's Avatar
sorry guys no vid yet. Its still below 30* here and snowing. While i was snowed in i finished the n2o install I used a edelbrock spraybar plate under the carb. I went to the local speed shop ,got my bottle filled and finally found a air cleaner i liked. vic. jr,3 inch cleaner all under a 2 3/4 cowl hood.SWEET
Old Mar 16, 2007 | 03:36 PM
  #37
6L.IROC-Z's Avatar
Dyno numbers are in
355hp & 348tq all motor
451hp & 498tq on a NOS brand 150 shot
Track opens next weekend !!!!!!! I am hoping for 10's on the spay
Old Mar 16, 2007 | 05:32 PM
  #38
QuickZ28's Avatar
such a nice nice swap...Im currently doing the same thing
lq4...Carbed/cammed....th350..
I wish youd post more pics, especailly of the bracket set up. I have to swap out the truck brackets for the camaro ones....and i need some good pics to work with...
How was the carb conversion....meaning the wiring n such....
The fuel system seems to be easy to set up, but what did you go with?
MORE PICS MORE PICS MORE VIDS MORE VIDS
Old Mar 18, 2007 | 08:28 PM
  #39
StngKlr's Avatar
Pretty good numbers there. 10.99 should be no problem for ya.
Mine just ran a 7.39@94 today. Bone stock LS1 with a 150 shot. I gotta figure out why the N2O keeps cutting in and out in 1st gear and it might go a little faster. 232/232 cam going in soon also.
Good luck.
Old Mar 19, 2007 | 12:26 AM
  #40
with a g5x2 cam shouldnt your hp numbers be a little higher?
