Pics of the ol "ROCK"
Old Mar 19, 2007 | 08:39 PM
  #41
TJ's Avatar
TJ
Originally Posted by Doughdog
Did you use the truck oil pan? Or did you swap for the ls1 pan? Was the converter custom to work with the lsx motor, or could a stock converter be used?
Thanks
truck pan is too deep.
it wont work for street applications.
all drag car, then yes.
setup is looking nice.
waiting on those track times.
4 days?
hahaha.
bet you are ancy.
Old May 20, 2007 | 08:20 AM
  #42
6L.IROC-Z's Avatar
Track times are in
on the motor
1.68 60'
7.48 at 90.15
11.73 at 114.56
spraying 2nd & 3rd
1.67 60'
7.41 at 95.68
11.47 at 120
Pulled a front tire. Still on a 3.42 10 bolt and stock susp.
Old May 20, 2007 | 08:49 PM
  #43
Dave88z's Avatar
Nice job 6L, you and TJ are making me jealous! I hope to get mine up and running this summer. Third gens rule
Old May 21, 2007 | 06:53 PM
  #44
ss02camaro35th's Avatar
that is one of the best looking third gens with the coolest engine setup i have seen. MUCH PROPS
Old May 21, 2007 | 07:10 PM
  #45
StngKlr's Avatar
Time to hit it out of the hole now.
Also, I couldnt be happier with these MT radials. No problems with the N2O out of the hole, and somehow the 10-bolt is holding up.
Old May 21, 2007 | 08:03 PM
  #46
PRAY HRD's Avatar
'bout time you get on here and post up your times! lol. my msd box is supposed to be here tomorrow so i'll be talkin' to you soon!
Old May 22, 2007 | 05:26 PM
  #47
6L.IROC-Z's Avatar
Next weekend I am going to spray it off the line. Hope the 10 bolt stays together.I installed the msd digital window switch so i fill better about spaying and me having to manually shifting the trans because its hit the rev limiter a time or two because I didnt shift. Stngklr, What does your car weight? Pray hrd give me a call
Old May 22, 2007 | 05:57 PM
  #48
BLWN1's Avatar
Did you start with a LQ4 or LQ9?
Old May 22, 2007 | 06:13 PM
  #49
6L.IROC-Z's Avatar
early iron headed lq4
Old May 22, 2007 | 06:14 PM
  #50
BLWN1's Avatar
bottom end same as the later models? Did you check clearances by chance? Good times, I would be happy with that out of mine....
Old May 22, 2007 | 07:30 PM
  #51
StngKlr's Avatar
I've never had the car weighed, but I'd guess somewhere around 3200. Aluminum block/heads, no A/C, some plastic interior pieces not there etc... But it does have both front seats and I have to have a stereo.
A window switch is good insurance. I doubt anyone could let out of it fast enough if a driveshaft was to give up.
What Torque Arm set-up do you have? I do remember my stock clamshell t/a mount exploding the very first time I sprayed at the line. Spohn got a call after that one. I guess I should have mentioned that before I tell you to hit it out of the hole. lol
Old May 23, 2007 | 02:14 PM
  #52
LSPerformance's Avatar
Hey StngKlr, what headers are on your car? - I'm thinking of the same swap with 1&7/8 pipes and don't want to have to build something.
Thanks
Old May 23, 2007 | 05:58 PM
  #53
StngKlr's Avatar
Thanks
01-02 manifolds. Infact, everything is stock on/in the motor. Headers are'nt out there for our cars with GenIII's in them. One company makes them and they are pricey and only 1.75 primary's and 2.5 collectors. Making them is about the only option.
Old May 23, 2007 | 07:40 PM
  #54
6L.IROC-Z's Avatar
The bottom ends are the same.
Old May 23, 2007 | 07:46 PM
  #55
6L.IROC-Z's Avatar
All susp. is bone stock I think the shocks are 87' original. so if my tourque arm doesnt come through the floorboard and a axle doesnt snap I should be happy what ever it runs?
Old May 24, 2007 | 12:01 PM
  #56
73cam's Avatar
Hey man!!
I may need your help now, as I finally got my 6.0L block and am ready to start buildin'!!!!
I am really interested in doing a L92 set-up......but definitely carb'd!!
Old May 25, 2007 | 09:34 PM
  #57
TJ's Avatar
TJ
i thought they were different.
lq9 has flat tops, beefier rods.
all motors had better rod bolts 2002+
Old May 26, 2007 | 07:17 AM
  #58
6L.IROC-Z's Avatar
I thuoght he was askining if the early lq4 (iron heads) and the later lq4 had the same bottom end. I think they are the same. Lq4 and Lq9 are different.
Old May 26, 2007 | 09:34 AM
  #59
BLWN1's Avatar
Yes, my question was lq4 only.....
Old Aug 10, 2007 | 07:00 PM
  #60
6L.IROC-Z's Avatar
New best times
1.68 60''
7.18 @ 94 mph 100 shot
