5000 lb conversion, what motor???
Conversion master
I am pre-planning a possible project and wanted to know what kind of power would it take to get a 5000lb car into the high 12's low 13's?
Those things weigh 5,000 lbs?!!! I knew they were big and heavy, but damn. You must be planning to totally load it with leather and everything. I always that it would be cool to put a modern FI motor in an old cruiser car like that. Good luck!
You'll need some torque to move you along.
A. Vortech supercharged 460 FI
B. ZZ 572 HP GM Crate Motor - HP: 620 @ 5500 RPM ·Torque: 650 Ft. Lbs. @ 4500 RPM ·Compression Ratio: 9.6:1
C. 502 RamJet w/MeFI4 - 500ftlb. of torque from 2200 to 5200 rpm the ram Jet 502 is a tire shredding monster
D. Ford Motorsports 514 - 625 HP @ 6250 RPM 600 ft./lbs. of torque @ 4800 RPM
Or a late model FI Mustang motor with a procharger.
If your going that heavy how about a turbo diesel? Theres a place called longs performance that always advertises in the illinois auto-rv trader with powerstroke, duramax and cummings complete engines that are new or were EPA test motors.
The bottom ends are plenty strong, just crank up the boost and dump some more fuel in. I read in one of the magazines about a programmer from someone on the west coast that turned up the boost and fuel on a turbo duramax and it was running 12`s in the 3/4 or 1 ton truck that it was in.
Learn from the Impala SS Crowd...4400 pounds for an Impala SS (94-96 vintage) and there's LOTS of guys with "stock" LT1's running mid 13's with good drivetrain work and intake/exhaust bolt ons...get into the station wagon crowd (caprice wagon) and you're up to like 4800 pounds and you see them with heads/cam and the same other bolt ons running LOW 13's (and one in the high 12's that I know of)...thats only 200 pounds away (so figure 2 tenths)...meanwhile another guy I know has a stock heads, TR224 cam 2002 LS1 and T56 in his 4300 pound Caprice sedan and he's seen like 12.3's at 111 mph...so I'd say a good heads/cam package on an LS1 and a highish stall converter, good gear and you should be all set...or T56 it and practice launching
So here again we see that, "if you got the money almost anything is possible."
ChrisP
Conversion master
Thanks for the comments. I was thinking of something in the LSx family like a turbo 427, but may have to use something in the Ford family.
And I am really thinking of converting to a T56.
I see no problems with getting enough power out of a LSx. A 6.0L and a couple turbos will push it no problem, just ask Parish.
I thought I would throw out the idea of a diesel since I know they can make enough power, you could get a ford turbo diesel and keep the car all for, plus it would be unique
