So here's the game plan 00 Mustang + LSx + huge turbo :)
Old 07-17-2007, 05:12 PM
  #241
smokeum99ta's Avatar
Originally Posted by Phil99vette
Yeah, if you saw it you would probably call "BS" on what I paid for most of my stuff. Its really not as high as most would expect. I've gotten deals on almost 100% of the parts I have gotten. My old corvette motor, wheels/tires, nitrous and misc paid for most of the stuff.
just kidding phil .... I had to pull the flag since you said so. I'll try and sneek over this weekend and check it out in person. Ken
Old 07-17-2007, 05:13 PM
  #242
7 Second Club
Phil99vette's Avatar
DAYAM, where have you been? I heard you moved out of the state.
Old 07-18-2007, 01:16 PM
  #243
7 Second Club
Got a few more little goodies on the way from Summit, Jegs and Moser Engineering.
Moser Rear End Brace
TheV 16/12 volt Lite battery
Handful of (-12) (-10) (-8) Black Summit Fittings straight 45 and 90
-12an to -10 O-ring adapter for fuel pump
-8 and -10 Plugs and adapters for the regulator
-8 -10 and -12 SS hose
Single -12 to dual -10 Y block from Jegs for fuel tank
Single -10 to dual -7 Y block from Jegs for fuel rails
Old 07-19-2007, 04:11 PM
  #244
DAVE97's Avatar
great project
Old 07-24-2007, 02:40 PM
  #245
7 Second Club
Knocked out a couple of things this morning:
- Mocked up upper IC pipe still needs to be bead rolled and welded
- Cut floor for thru floor rear cross-member & installed rear cross member
- started mocking up cage for custom window net
- Removed stud and mocked up brake pedal for manual conversion
- Installed auto brake and gas pedal & welded on tab for carb throttle cable
- welded passenger side collector - passenger side header is 90% done now
- welded rear brace on Moser 9"
- welded rear sway bar tabs on rear end
- filled in holes on rear wing with fiberglass and started body work on rear facia, driver door to remove 3 small dings
- Intake manifold is done except for some spacers between the mounts and the fuel rail tabs, I had a local shop drill the injector bungs and we tapped the mounts
- cut plate for blockoff to close hole for manual shifter in center console
- made tab for throttle cable to firewall
- Mounts for radiator are ready to be mocked up
Motor is done @ the machine shop, I need to pick it up and take it to have the o-ring installed
Old 07-24-2007, 05:03 PM
  #246
carreras's Avatar
Good luck, keep us posted. Its gonna b e sweet.
Old 07-25-2007, 01:06 AM
  #247
LSInnovations's Avatar
How the hell do you get so much done in a day???? Geez, do you want a job?
Old 07-25-2007, 01:20 AM
  #248
1dirtyZ's Avatar
we demand pics as proof
Old 07-25-2007, 04:16 AM
  #249
mcamarols1's Avatar
wow good job!!! make sure u get not only pix BUT MORE IMPORTANTLY VIDEOS of that baby running and at the track
Old 07-25-2007, 07:15 PM
  #250
7 Second Club
I'll have more pics tomorrow, right now we're trying to figure out if we should add some bars on the nose of the car to stop the chassis flex infront of the firewall.
Old 07-26-2007, 07:11 PM
  #251
7 Second Club
I've got alot more pic's coming. I did ALOT of work today and made alot of progress. Motor is done @ the machine shop and just needs to be taken to Jackson to get the CNC o-ring installed.
Sway bar was orginally installed but the bar was too low and we couldn't get the tires tucked up under the car enough so I cut it out and started fresh. I raised the bar about 2" and made some custom plates. The suspension will basically bottom out on the frame rails now. I may need to move the front upper control arm points up slightly.
Passenger side swaybar mockup
Overall Mockup shot
Making the sway bar plates
Tig - Swaybar cup weld
Swaybar end plates finished ready for installation
Mig - Swaybar mount weld
Just got battery - will mockup mounts and box this weekend
Mockup for custom window net from M & R products, template leaves tomorrow - turnaround time 1 week
New pedals with tab for pull style carb cable
Interior shot
Driver side motor starting to look like a motor
Driver header collector shot - getting closer
Rear crossmember - thru floor design
3000hp intercooler under dash
Shifter blockout plate
Rear cage X bars to be installed this weekend
rear cage underside 2 x 3 outriggers - rear crossmember
Rear torque box plates
Old 07-26-2007, 07:25 PM
  #252
White.Lightning's Avatar
They're some nice welds there! I've been following this thread for a while now. Class A buildup. I can't wait to hear the thing fire up!
Keep 'em coming
Andy
Old 07-26-2007, 07:41 PM
  #253
7 Second Club
Overall Mockup shot
Interior shot
Old 07-27-2007, 03:51 PM
  #254
singe's Avatar
Your my hero Phil! ha
Old 07-27-2007, 03:57 PM
  #255
slowmofo's Avatar
man this projest is sweet, i can't wait to see it done
Old 07-27-2007, 08:39 PM
  #256
7 Second Club
Just got the Jesel Rockers for the ETP 4.1 LS7 heads and they are still not right but we can swap out the parts here.
Old 07-28-2007, 01:13 AM
  #257
$ho_tyme's Avatar
LOL thats what I am thinking. He has alot better train of thought. I allwayz start something and before I get done move to another.
Is there any ETA when it will hit the track?
Old 07-28-2007, 08:32 AM
  #258
7 Second Club
Once a week, I made a 40-50 thing to do list and I just go down the list. I am so much more productive going down the list. I usually get 10-12 things done a day where before I would only get 3-4.
Phil
Old 07-29-2007, 12:28 AM
  #259
FSANE's Avatar
I guess you already passed the 6 o 7 month deadline.
Old 07-29-2007, 01:25 AM
  #260
LSWaaa?'s Avatar
subscribing!
Quick Reply: So here's the game plan 00 Mustang + LSx + huge turbo :)
