LS1/T56 - while it's out
Old Jan 14, 2007 | 03:12 PM
ssv's Avatar
ssv
Default LS1/T56 - while it's out
Any recommendations on things to change (respect to maintenance) not looking to get more power at this point.
It's a 01 Camaro SS L1/T56 engine with 33K miles on it; I will be putting it into a 69 Camaro.
Old Jan 14, 2007 | 05:28 PM
a10beav's Avatar
Might as well change the clutch. It would also be easier to change the cam while its out.
Old Jan 14, 2007 | 06:53 PM
baldurann's Avatar
Swap out the factory rod bolts for some ARP or Katech ones, swap out the clutch, and maybe swap out the pulley tensioner.
Old Jan 14, 2007 | 07:03 PM
firefighter's Avatar
Pistons too. just gives you more options later on to have forged pistons.
Old Jan 15, 2007 | 12:27 AM
bczee's Avatar
Oil pump and New O-Ring for the pickup tube.
Old Jan 15, 2007 | 07:34 AM
yeah should always do the oil pump on any motor cheap insurance it's alot easier when the motor is out.
Old Jan 15, 2007 | 07:42 AM
Cam72aro's Avatar
Default oil pump, cam, pistons
I understand that the pistons comment was a joke, but an oil pump at 33k miles? C'mon guys. Lets not give someone that is just getting into the ls1's the wrong idea. I would inspect the clutch and flywheel and also make sure there arent any oil leaks, if not then your ok. Did yall not read where it said maintence, not wanting to get more power. You shouldnt have really anything wrong and need to go into the motor. Hope this is helpful, Josh
Old Jan 15, 2007 | 07:49 AM
correct we lost the "maintenance" part but we were going with the while it's out mentality make it easier for later. really he could just throw it in there and call it a day. I mean it is a Chevy right?
Old Jan 15, 2007 | 09:21 AM
Cam72aro's Avatar
Default while its out
While mine was out I did cam, all new gaskets, ported the heads, valve spring, clutch, flywheel, etc. I would have liked to do pistons, and rod bolts. It is a chevy though. Put it in and run it.
Old Jan 15, 2007 | 02:10 PM
datboibrad's Avatar
ported oil pump is like 150-160 bux. do it just because.
Old Jan 15, 2007 | 02:47 PM
Silver1969Camaro's Avatar
Are you kidding? At 33K miles?
Guess you better swap the water pump too.
Old Jan 15, 2007 | 03:17 PM
Cam72aro's Avatar
Default oil pump
Water pump, that was a good one. How about the starter, alternator, all the injectors, etc. I dont know about most guys on here but I am on a budget. I spend my money where it counts. My motor has 60,000 miles, I did a cam swap and didnt change the oil pump. I got some flack from a few people, but I think it was money saved.
Old Jan 15, 2007 | 03:50 PM
silicone boy's Avatar
I fell for that one, only because that's what I do in real life. I think to myself.....It would be that much better if I changed this, and that, and that, ....hell you might as well change out the block while you are at it.
Old Jan 15, 2007 | 04:46 PM
Project GatTagO's Avatar
Honestly if your not looking to make any more power than stock, I would change nothing. Possibly a new clutch, but I would measure the disk first to see what kind of wear it has.
Andrew
Old Jan 15, 2007 | 05:07 PM
bczee's Avatar
If you think changing a Oil Pump with only 33k on it is overkill. .suggest you search on Low or no Oil pressure problem in the forums...
My take out (99 LS1) was suppose to have low miles.. (40k)..and on starting it up after being ins torage for almost a year.. I had either very low or no oil pressure and had to remove the engine (to change to a new stock LS6 pump and new O-ring) to fix the problem.
Old Jan 15, 2007 | 05:44 PM
76LS1BIRD's Avatar
Restricted User
Spark plugs,& trans fluid.
Old Jan 15, 2007 | 05:47 PM
G-Body's Avatar
sawzall wielding director
The oil pump was a big issue on the 97-00 LS1`s, but the newer ones had better quality control and are a lot less likely to fail.
I would say change it anyway if you are in there doing a cam and timing chain, but if you are going to keep the motor stock you probably don`t need to worry about it. My oil pump has 140k on it and it still pushes 40-60 pounds at anything over idle.
