drilling the passenger head for a guage
Old Jan 21, 2007 | 08:40 PM
68 CHEVELLE IN CALI's Avatar
Default drilling the passenger head for a guage
does any one know if I can drill and tap my 314 passenger side head for the capilary tube and 1/2 npt sealing nut without any damage
Old Jan 21, 2007 | 09:31 PM
99c5vert's Avatar
I don't know, but if you're going to drill your passenger's head for a gauge, you best not post about it. That's premeditated.
Old Jan 21, 2007 | 10:22 PM
Lol, Funny, Hah Hah
Old Jan 22, 2007 | 05:08 AM
LS1MCSS's Avatar
I drilled mine for an electric sender, but I can't remember if it was 1/2 or 3/8 and my heads were stock 2000 models, whatever casting they are.
Old Jan 22, 2007 | 11:07 AM
Novas Forever's Avatar
I was leery of drilling for a 1/2 NPT. I did a 3/8 but that is all I wanted to go.
Old Jan 22, 2007 | 11:36 AM
LS1MCSS's Avatar
I am pretty sure mine is 3/8 also.
Old Jan 22, 2007 | 12:11 PM
bczee's Avatar
I drilled and taped for 3/8" also.. most if not all manufactors of gauges have there senders in different size 1/2", 3/8" or 1/4".. or have adapters. There is also a Metric adapter to NPT if you want. but it start to stick out some once use use the adpater and sender, if you have the space.. no problem then.
I have seen some pictures with 1/2" ones being used.... but since I was able to get mine in 3/8", that also as far as I needed to go.
Old Jan 22, 2007 | 12:53 PM
ghettocruiser's Avatar
Just out of pure curiousity...Why go through all that trouble? Why not run an electric sender, and just get the adapter bushing that most of us "swap" guys do?
I have an electric sender mounted in the rear of the pass. head that runs an autometer gauge. And I have a scan gauge mounted that can display the coolant temp sensor reading too. They are spot on...so the elec gauge in that spot is reading accuratly.
Just curious...drill into the head sounds scary for something like that. If there was a huge difference between an electric sender and a capilary style sender (mechanical gauge) then maybe I could see doing that?
Justin
Old Jan 22, 2007 | 01:06 PM
i already have the guages from my last engine
Old Jan 22, 2007 | 01:09 PM
i will see if i have an adapter that the capilary tube fits into
but i just wanted it clean
Old Jan 22, 2007 | 01:18 PM
Yeah I can understand the "already had the gauges" scenario. Been there before
Im not sure you will find an adapter to go from that hole in the head up to the sealing nut for the calipary tube. Adapters like that usually go down in size...but I could be wrong.
Good luck tho man! If you drill the head, take lots of pictures and do a write up on here... that will surely help someone else out that is in your position!
Justin
Old Jan 22, 2007 | 01:23 PM
bczee's Avatar
Search for this subject here.. as some have posted info on it and using the adapters..
Old Jan 22, 2007 | 09:09 PM
Cop Car's Avatar
isnt there already a hole?
Old Jan 22, 2007 | 09:27 PM
yes there is a hole but the dia is approx .475 , i was wondering if there was enough material for 1/2 npt thread which the minor dia is approx .718
Old Jan 22, 2007 | 10:23 PM
Old Jan 23, 2007 | 04:32 AM
Kyle1974's Avatar
S&P has an adaptor that goes from metris to 1/2'' npt. If I am not mistake it is around $25.
Old Jan 23, 2007 | 10:12 AM
Thanks Kyle
I Will Look Into That
Old Jan 23, 2007 | 10:44 AM
bczee's Avatar
I beleive that it is a 12x1.5mm thread and is an adapter.
https://ls1tech.com/forums/showthrea...mp+sender+head
Old Jan 23, 2007 | 11:55 AM
Well the adapter that most of us use is the 12x1.5mm to 1/8" NPT adapter. Im not sure you can go from the threads in the head up to 1/2" NPT for the mechanical temp sender...
If you build enough adpaters together to make something like that work, you might run into a space issue back there...depending on your set up in the engine bay.
Justin
