Quick question about chassis.
You can check to make sure your sub-frame is square by measuring crosswise, You can also check the spec in you Factory manual.
They also suggest that you mark or drill some location holes so that you can make sure as you re-assemble it, that it goes back in the same location on the Body (critical if you want to be straight agian)
You can also try tapping the spindle down on to the Ball Join to see if the Stud will seat and lock in place (not to much force tho..)
