How hard to do a LS1 swap in a 3rd Gen?
Hawk 3rd Generation has everything you need... as well as a few other known supplier of hardware and equipement for his swap.
Just get the harness with the LS1 and all of the Accessories and have it converted to a standalone harness. Would not suggest Painless. Talk too speartech for your harness and PCM needs..
https://ls1tech.com/forums/conversions-swaps/641467-how-hard-lsx-swap-3rd-gen-fbody.html
Also, check on thirdgen.org . Lots more thirdgen oriented info over there. Between the two sites, you should be able to accumulate all the info you can handle.
Justin
http://www.hawksthirdgenparts.com/in...S&Category=691
i had an 85 IROC, and an LS1, i ended up trading the IROC for a V6 camaro to swap the motor into becuase it was going to be much easier and cheaper.
LS1 tank goes into the third gen... and you just need to get motor and trans mounts, and for about $300 you can have the motor and trans physicaly in the car, then the headaches of swap start... getting wiring etc.
If he does the swap with a donor car like I did, about the only headache will be wiring as you said. However with the donor car comes the relay boxes and plugs etc. Its super easy to cut out what you arent using, hook power to the boxes, plug the engine into their stock plugs, and basically be able to run it. Then the only thing he needs to do is get fuel to the engine and disable vats.
If the wiring seems wayyyy too nightmareish for you...you can always plop down alittle more cash and go with a speartech ready to go harness. Everyone seems to love them, and while I never used one of their products, I did call their shop with a tech question, and they were nice enough to help me out even though I wasnt a customer.
Post up a couple pics of your car when you get a chance!!! I dig the 88+ IROCS
Justin
"Old School huh?" was his first words.
"Not quite" was my reply as I popped the hood.
Kevin D.
Third Gens werent known for there horsepower, they were known there great handling and of course looks...they have beautiful lines.
On the topic of ls1 swap...just get on over to thirdgen.org and ull find all you need to know. Its been done lots and lots of times and there are plenty of guys over there to give you pointers and tips. Good luck.
