It's Aliiiiivvvvve!
Well guys, at about 12:40a.m. this morning my Ls6 in my '90 silverado woke up!
I've heard others on here post how easily their carb conversion fired up and idled
and it is true. All my factory guages work and everything seems to be in good
shape. Just wanted to let you guys know. And I know
I'll have some later.
![This thread is worthless without pics](https://ls1tech.com/forums/images/smilies/threadworthlesswithoutpics.gif)
Edelbrock performer RPM manifold with a 625 Road Demon per their tech line with my
specs. They said it would handle the Ls6 up in the low 400's hp and have perfect off-idle
and part throttle drivability.
Originally Posted by Ls1olds
So for the fuel system are you just running a stock in tank pump with adjustable regulator or what are you using ? just curious, thanks!
to do a new system this summer.
what psi does the stock 454 tbi pump run at? is it a lot bigger than the pump they put in the 350 tbi trucks?? i didnt think mine would come anywhere near supplying enough pressure for my 6.0
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Originally Posted by mmmchickenboy
shoot me if im wrong, but TBI runs at REALLY low pressure, like 1/4 of what SFI runs nowadays.. 10-15psi maybe?
inj. you'll have to go with a higher output pump.
Originally Posted by 91redchevy
Yeah, thats what they run and it's good if you're gonna run a carb, but for fuel
