Drive by wire conversion to throttle cable?
Thanks.
Kyle
You can add the wiring for the T.B. yourself if you have the capability, or contact one of the wiring sponsors to add it for you. I would assume they could take care of the programming as well.
RYANVV355, you completly lost me on that. I already have the 8.1's 2002 wiring harness for the 2002 8.1 engine and a supposedly 2002 cable throttle body. Can you dumb it down for me? As to cruise control, I am not worrying about it.
There is no reason to go back to an earlier computer. The '03-up ECM can be flashed as an Express Van with a cable TB and that'll take care of that.
Then just add the wires for the IAC and TPS which are the same pins as an '02 truck
Nevermind, just realized you are talking about an 8.1L now, I was thinking we were still talking about the 5.3's
Evidently I am not making myself clear or I DEFINITELY do not understand (or both). I have a complete 02 harness, an 02 computer (both came from the donor vehicle for the 02 8.1 engine) and an advertised 02 cable throttle body. I have an additional wiring "port" on the cable throttle body that the 02 drive by wire throttle body did not have (see above pictures). It also has additional vaccuum ports that the drive by wire did not have (see above pictures). If I have to add wires, ok, but where do I add them too? Where do the vacuum ports go (Should I just plug them)? I have searched, but if anyone can point me in the right direction for a better understanding on this adding wires process, please do!Thanks and I apologize for the redundancy. Just trying to make this clear in my mind.
