pcm pinouts for a 03 4.8L
If you get lucky someone here might have them. You could also try talking to a tech at the dealer, if he`s really nice he might print them out for you(don`t hold your breath on this one, its never worked for me). Or you can always get an alldata.com account, they will have all the pinouts/diagrams you will need, but they charge for it .
Alldata. Not too expensive and everything is there that I needed. My hometown Chevy service man was extremely helpful, gave me all the printouts for the 2005 5.3 that I have. Maybe rare, but in this case, it happened. Russellville Arkansas. Went to alldata anyways, and got accounts for all my vehicles.
http://www.fbody.com/tech/details.cgi?id=55
these should work. note that these are from a 1998 ls1 so there my be slight diffrences.
'03 4.8L
Connector Part Information
• 12191489
• 80 way F Micro-Pack 100 Series (BLU)
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
Ground
2
LT GRN
1867
12 Volt Reference
3
PNK/BLK
1746
Fuel Injector 3 Control
4
LT GRN/BLK
1745
Fuel Injector 2 Control
5-6
Not Used
7
GRY
2705
5 Volt Reference
8-10
Not Used
11
LT BLU
1876
Knock Sensor 2 Signal
12
DK BLU/
WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
Requested Torque Signal (NW7)
14
ORN/BLK
1061
UART Serial Data
15
DK BLU/
WHT
774
UART Serial Data
16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B (A/T)
18
RED
1226
Transmission Fluid Pressure Switch Signal C (A/T)
19
PNK
439
Ignition 1 Voltage
20
ORN
440
Battery Positive Voltage
21
YEL/BLK
1868
Low Reference
22
Not Used
23
BLK
470
Low Reference
24
BLK/WHT
451
Ground
25
TAN
1671
HO2S Low Signal - Bank 2 Sensor 2
26
TAN
1667
HO2S Low Signal - Bank 2 Sensor 1
27
BLK/WHT
451
Ground
28
TAN/WHT
1669
HO2S Low Signal - Bank 1 Sensor 2
29
TAN
1664
HO2S Low Signal - Bank 1 Sensor 1
30
LT GRN
1478
Coolant Level Switch Signal
31
Not Used
32
BLK/WHT
771
Transmission Range Switch Signal A (A/T)
33
PPL
420
TCC Brake Switch/Cruise Control Release Switch Signal
34
WHT
776
Transmission Range Switch Signal P (A/T)
35
GRY
48
CPP Switch Signal (M/T)
36
BLK
1744
Fuel Injector 1 Control
37
YEL/BLK
846
Fuel Injector 6 Control
38
PNK/WHT
1101
Damping Lift/Dive Signal
39
YEL/BLK
625
Starter Enable Relay Control
40
BLK/WHT
451
Ground
41-42
Not Used
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
GRY
2700
5 Volt Reference (A/C)
46
GRY
474
5 Volt Reference (EVA)
47
Not Used
48
GRY
597
5 Volt Reference
49-50
Not Used
51
DK BLU
496
Knock Sensor 1 Signal
52
Not Used
53
GRY
720
Low Reference (A/T)
54
ORN/BLK
469
Low Reference
55
Not Used
56
WHT
1579
Fuel Temperature/Composition Signal (L59)
57
ORN
440
58
DK GRN
1049
Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
Not Used
61
PNK/BLK
632
Low Reference
62
Not Used
63
BLK
2755
Low Reference
64
BLK/WHT
451
Ground
65
PPL
1670
HO2S High Signal - Bank 2 Sensor 2
66
PPL
1666
HO2S High Signal - Bank 2 Sensor 1
67
BLK/WHT
451
Ground
68
PPL/WHT
1668
HO2S High Signal - Bank 1 Sensor 2
69
PPL/WHT
1665
HO2S High Signal - Bank 1 Sensor 1
70
BRN
1174
Oil Level Switch Signal
71
Not Used
72
YEL
772
Transmission Range Switch Signal B (A/T)
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
Off/Run/Crank Voltage
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/
WHT
878
Fuel Injector 8 Control
78
Not Used
79
WHT
687
3-2 Shift Solenoid Valve Control (M30/M32)
80
BLK
407
Low Reference
__________________________________________________ _______________
• 12191488
• 80 way F Micro-Pack 100 Series (GRN)
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
Ground
2
BRN
418
TCC PWM Solenoid Valve Control (A/T)
3
TAN
1465
Fuel Pump Relay Control - Secondary (Dual Tanks)
4
Not Used
5
TAN/BLK
464
Delivered Torque Signal (NW7)
6
RED/BLK
1228
PC Solenoid Valve High Control (A/T)
7
Not Used
8
LT BLU/WHT
1229
PC Solenoid Valve Low Control (A/T)
9
DK GRN/
WHT
465
Fuel Pump Relay Control - Primary
10
WHT
121
Engine Speed Signal
11-13
Not Used
14
RED/BLK
380
A/C Refrigerant Pressure Sensor Signal (A/C)
15
BRN
25
Charge Indicator Control
16
GRY/BLK
1694
4WD Low Signal
17
Not Used
18
DK GRN
1433
Clutch Start Switch Signal (M/T)
19
BLK/WHT
1695
Axle Switch Signal (NP2)
20
LT GRN/BLK
822
VSS Low Signal
21
PPL/WHT
821
VSS High Signal
22
RED/BLK
1230
AT ISS High Signal (4WD w/MT1)
23
DK BLU/
WHT
1231
AT ISS Low Signal (4WD w/MT1)
24
Not Used
25
TAN
472
IAT Sensor Signal
26
PPL
2121
IC 1 Control
27
RED
2127
IC 7 Control
28
LT BLU/WHT
2126
IC 6 Control
29
DK GRN/
WHT
2124
IC 4 Control
30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
Not Used
34
DK GRN/
WHT
428
EVAP Canister Purge Solenoid Control
35-38
Not Used
39
RED
631
12 Volt Reference
40
BLK/WHT
451
Ground
41
Not Used
42
TAN/BLK
422
TCC Solenoid Valve Control (M30/M32)
43
DK GRN/
WHT
459
A/C Compressor Clutch Relay Control (A/C)
44
Not Used
45
WHT
1310
EVAP Canister Vent Solenoid Control (EVA)
46
BRN/WHT
419
MIL Control
47
YEL/BLK
1223
2-3 Shift Solenoid Valve Control (A/T)
48
LT GRN
1222
1-2 Shift Solenoid Valve Control (A/T)
49
YEL/BLK
1827
Vehicle Speed Signal
50
DK GRN/
WHT
817
51
YEL/BLK
1227
TFT Sensor Signal (A/T)
52
BRN
2391
HO2S Heater Low Control Bank 1 Sensor 2
53
RED/WHT
3223
HO2S Heater Low Control Bank 2 Sensor 2
54
PPL
1589
Fuel Level Sensor Signal - Primary
55-56
Not Used
57
BLK
552
Low Reference
58
TAN/WHT
332
Oil Pressure Sensor Signal
59
PPL
806
Crank Voltage
60
BRN
2129
Low Reference
61
BRN/WHT
2130
Low Reference
62
GRY
773
Transmission Range Switch Signal C (A/T)
63
PNK
1224
Transmission Fluid Pressure Switch Signal A (A/T)
64
DK GRN
890
Fuel Tank Pressure Sensor Signal (EVA)
65
Not Used
66
PPL/WHT
2128
IC 8 Control
67
RED/WHT
2122
IC 2 Control
68
DK GRN
2125
IC 5 Control
69
LT BLU
2123
IC 3 Control
70-71
Not Used
72
BLK/WHT
3113
HO2S Heater Low Control Bank 1 Sensor 1
73
DK BLU
1936
Fuel Level Sensor Signal - Secondary
74
LT GRN
3212
HO2S Heater Low Control Bank 2 Sensor 1
75
GRY
23
Generator Field Duty Cycle Signal
76-79
Not Used
80
BLK
2751
Low Reference (A/C)
• 12191489
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
Ground
2
LT GRN
1867
12 Volt Reference
3
PNK/BLK
1746
4
LT GRN/BLK
1745
5-6
Not Used
7
GRY
2705
5 Volt Reference
8-10
Not Used
11
LT BLU
1876
12
DK BLU/
WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
14
ORN/BLK
1061
UART Serial Data
15
DK BLU/
WHT
774
UART Serial Data
16
Not Used
17
DK BLU
1225
18
RED
1226
19
PNK
439
Ignition 1 Voltage
20
ORN
440
21
YEL/BLK
1868
Low Reference
22
Not Used
23
BLK
470
Low Reference
24
BLK/WHT
451
Ground
25
TAN
1671
26
TAN
1667
27
BLK/WHT
451
Ground
28
TAN/WHT
1669
29
TAN
1664
30
LT GRN
1478
31
Not Used
32
BLK/WHT
771
33
PPL
420
34
WHT
776
35
GRY
48
36
BLK
1744
37
YEL/BLK
846
38
PNK/WHT
1101
39
YEL/BLK
625
40
BLK/WHT
451
Ground
41-42
Not Used
43
RED/BLK
877
44
LT BLU/BLK
844
45
GRY
2700
46
GRY
474
47
Not Used
48
GRY
597
5 Volt Reference
49-50
Not Used
51
DK BLU
496
52
Not Used
53
GRY
720
Low Reference (A/T)
54
ORN/BLK
469
Low Reference
55
Not Used
56
WHT
1579
57
ORN
440
58
DK GRN
1049
Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
Not Used
61
PNK/BLK
632
Low Reference
62
Not Used
63
BLK
2755
Low Reference
64
BLK/WHT
451
Ground
65
PPL
1670
66
PPL
1666
67
BLK/WHT
451
Ground
68
PPL/WHT
1668
69
PPL/WHT
1665
70
BRN
1174
71
Not Used
72
YEL
772
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
76
BLK/WHT
845
77
DK BLU/
WHT
878
78
Not Used
79
WHT
687
80
BLK
407
Low Reference
• 12191488
Pin
Wire Color
Circuit No.
Function
1
BLK/WHT
451
Ground
2
BRN
418
3
TAN
1465
4
Not Used
5
TAN/BLK
464
6
RED/BLK
1228
7
Not Used
8
LT BLU/WHT
1229
9
DK GRN/
WHT
465
10
WHT
121
Engine Speed Signal
11-13
Not Used
14
RED/BLK
380
15
BRN
25
16
GRY/BLK
1694
4WD Low Signal
17
Not Used
18
DK GRN
1433
19
BLK/WHT
1695
20
LT GRN/BLK
822
VSS Low Signal
21
PPL/WHT
821
VSS High Signal
22
RED/BLK
1230
23
DK BLU/
WHT
1231
24
Not Used
25
TAN
472
IAT Sensor Signal
26
PPL
2121
IC 1 Control
27
RED
2127
IC 7 Control
28
LT BLU/WHT
2126
IC 6 Control
29
DK GRN/
WHT
2124
IC 4 Control
30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
Not Used
34
DK GRN/
WHT
428
35-38
Not Used
39
RED
631
12 Volt Reference
40
BLK/WHT
451
Ground
41
Not Used
42
TAN/BLK
422
43
DK GRN/
WHT
459
44
Not Used
45
WHT
1310
46
BRN/WHT
419
MIL Control
47
YEL/BLK
1223
48
LT GRN
1222
49
YEL/BLK
1827
50
DK GRN/
WHT
817
51
YEL/BLK
1227
52
BRN
2391
53
RED/WHT
3223
54
PPL
1589
55-56
Not Used
57
BLK
552
Low Reference
58
TAN/WHT
332
59
PPL
806
Crank Voltage
60
BRN
2129
Low Reference
61
BRN/WHT
2130
Low Reference
62
GRY
773
63
PNK
1224
64
DK GRN
890
65
Not Used
66
PPL/WHT
2128
IC 8 Control
67
RED/WHT
2122
IC 2 Control
68
DK GRN
2125
IC 5 Control
69
LT BLU
2123
IC 3 Control
70-71
Not Used
72
BLK/WHT
3113
73
DK BLU
1936
74
LT GRN
3212
75
GRY
23
76-79
Not Used
80
BLK
2751
Low Reference (A/C)
