s10 ls1 guys......
im dealing with the same clearance issues except i have fans inside my engine bay. im not moving the rad or condenser, nor is the engine moving. since no intake hoses will work, not even the cobra head, the only other option is to get your lego set out and make your own tube to curve around that corner and still salvage some space between the rad.
s10_ls1, thanx for all that info but this isnt a for sale section.
Different subject...Shifter...??
I don;t have a Neutral saftey switch....can someone please direct me to a shifter that works good??...right now i have some angle iron running up through the floor that works...but it's not practical
pics would be great too..of your center consle
The reason you have hood clearance issues is because the engine is sitting so high up in order to clear the steering box.
I bet that truck has horrible vibrations at higher speed considering what the drive-line angle must be.
Side job or not, I hope you got a hell of a deal.
http://currentperformance.com/Samples/BlackX.html
You can notch the frame on the passenger side to obtain clearance for the A/C compressor.
You may have to also either modify an oil pan or notch and brace the front crossmember for oil pan clearance.
A couple of guys have done this swap with truck accessories successfully, but the vette accessories provide the greatest amount of clearance.
Then you need to work on the exhaust......
A rack and pinion steering setup is now available for the 2WD trucks. This may provide you with another option.
The LS2 / LS7 water pump has a flat faced pulley instead of the dome shaped pulley that the LS1 / LS6 has. Which means the LS2 is at least 1" shorter than the LS1 pump.
'JustDreamin'
Conversion was finished about 3 months ago. There is roughly 2500 miles on the conversion. I DD the truck to my highschool which is about 4-5 miles away and work which is about 1/2 mile away so I don't put aton of miles on it.
Since the odometer is broke, it is kinda hard to determine gas mileage. I'd say around 18 MPG in the city and probably mid-high 20's on the highway. (Truck is an auto). When the V6 was in the truck it had the stock 20 gallon gas tank. Now it only has a 12 gallon fuel cell. The gas gauge goes down about the same rate it used to so obviously gas mileage is alot better. Especially on the highway.
So far temp is doing great. Hottest weather it has been in is only about 80 degrees though. But from seeing it so far it should do fine it hot weather because in 80 degree weather it will sit there and idle all day without going over the 1/4 mark on the temp gauge. When it starts to really warm up here in a few months I'll test it with AC on and see how it does. Since I live in AZ, letting it idle in the summer with AC on should test how well it really cools.
Incase you were wondering....It has a 180 thermostat, using the stock 4.3 aluminum radiator, and flex-a-lite 210 fans with the fan speeds lowered. Cowl hood probably helps abit as well.
The front feels basically the same as it used to, possibly abit lighter, definately not heavier.
Thanks for the compliments
