Fbody vs. GTO Accessories placement
Old Feb 9, 2007 | 09:42 PM
jfman's Avatar
Default Fbody vs. GTO Accessories placement
Is there a difference in the way accessories are placed on GTO's and 98-02 Fboy cars ?
I was prepping my car to receive an ls1 but now I am going for an ls2 combo out of a GTO.
Old Feb 10, 2007 | 06:54 AM
downset71's Avatar
i am using 04 gto setup in a-body. from i am told the gto setup is the closest to the block setup.alt. is hung very LOW on drivers side, under p/s. air comp. is also very LOW on pass side.
Old Feb 10, 2007 | 07:03 AM
jfman's Avatar
What style mounts are you using ?
Did you have to notch the frame for the AC comp ?
Old Feb 10, 2007 | 04:47 PM
downset71's Avatar
i used the blueprints from the sticky sections and made BRP style mounts out of 1/4 steel plate. then just bought energy suspension mounts.for the air, i didnt notch because im probably gonna make or buy high mount brackets. also used factory f-body exhaust manifolds on my setup.clear everything,paid 30.00 for them(sold the gto manifolds for 45.00), are nice and quiet, and also make just a little less power than headers. the car is setup for crusin, not 1/4 mile.
Old Feb 10, 2007 | 07:06 PM
jfman's Avatar
I got BRP style mounts too.
GTO and Fbody have different manifolds ?
Could you have kept you ac where it belong if you wanted to notch ? (just like the fbody)
Old Feb 10, 2007 | 08:35 PM
stevieturbo's Avatar
The PAS pump is different, with a remote reservoir.
But locations of all items are still the same as an F-Body.
Old Feb 10, 2007 | 08:37 PM
jfman's Avatar
Ok sounds great
Are all the sensors and electrical connectors the same as an ls1 ?
Old Feb 10, 2007 | 08:44 PM
I dont know the differences between the LS1 and LS2 variants. But I'd say they are all the same.
If there are any changes, they would be very minor.
I do know their accessories though. I originally bought a Camaro engine for my install, but ended up having to buy a Aussie PAS pump, to suit my blower bracket.
A/C, alternator etc were exactly the same for both cars.
Old Feb 12, 2007 | 07:05 PM
downset71's Avatar
gto manifolds exit pretty much right under the third cylinder from front, which hit my engine crossmember. f- bodys look more like shorty headers you could purchase from like flowtech or any other header brand. the pass side exits on a 45 angle following the angle of firewall, all the way back under the last cylinder, the drivers side is a real shorty style also and almost exits straight down below the last cylinder.
Old Feb 12, 2007 | 07:53 PM
jfman's Avatar
Ah ok ! thanks for thew info..
