GM ITT plastic fuel line service parts
Old 02-20-2007, 10:53 PM
01WS6/tamu's Avatar
Default GM ITT plastic fuel line service parts
Does anyone know where you can get the oem gm itt plastic fuel line in bulk length or the connectors to fit a fuel rail short of a salvage yard.
Old 02-20-2007, 11:26 PM
ROCNDAV's Avatar
I know autozone sells GM plastic fuel lines with quick disconnect fittings. Not sure if its is the pump side or the fuel rail side. I've seen it at several autozones above the "help" brand items. Usually top shelf on the right side.
Old 02-20-2007, 11:35 PM
01WS6/tamu's Avatar
I'll have to check that out if I can just find the connectors that's hlaf the battle
Old 02-20-2007, 11:55 PM
Stu Cool's Avatar
Dorman makes a lot of different fittings in both plastic and steel. Ask your parts house if you can look at their catalog or search their website online. Hopefully you will find what you are looking for. Most of them are listed under repair fittings and lines.
PAt
Old 02-21-2007, 01:16 AM
eagleuh1's Avatar
Napa carries a repair kit that has a bunch of fitting and bulk line and tools in it.
Old 02-22-2007, 05:53 PM
datboibrad's Avatar
we sell them at autozone. its the plastic end (which imo are far easier to use than the metal ones) about a foot and a half of the tubing and a double ended fitting to splice to the old line. itsl ike 19.99 comes in 5/16 and 3/8.
Quick Reply: GM ITT plastic fuel line service parts
