Our LS4/4T65E Fiero conversion
Old 02-26-2007, 09:05 AM
Super Moderator
Reckless's Avatar
Default Our LS4/4T65E Fiero conversion
Not really a Fiero any more, but a stretched Fiero kit car (Lambo Diablo). Guess the little V-6 was not getting it done, so we are installing the new setup wtih heads and cam, Shrifter, and Momo wheel. Not sure about the PCM just yet. Will probably end up using a BS3, but not 100% sure yet. Only have a few shots so far. We made a brace to suspend the combo, and have removed some of the cradle and the cross-piece installed when the car was stretched. These will be replaced with similar structure that works better with the LS4 mounts. We will also be eliminating the displacement on demand stuff.
Attached Thumbnails Our LS4/4T65E Fiero conversion-lambo-15.jpg   Our LS4/4T65E Fiero conversion-lambo-14.jpg   Our LS4/4T65E Fiero conversion-lambo-13.jpg   Our LS4/4T65E Fiero conversion-lambo-12.jpg
Old 02-26-2007, 08:14 PM
9 Second Club/LS1TECH Sponsor
Speartech's Avatar
That should be a screamer! The LS4 is the ideal way to go on any transverse mounted swap.
I would think the stock computer would be the best way to control the whole assembly, but I know you guys are big fans of BS3.
Keep us updated.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old 02-27-2007, 03:53 PM
Super Moderator
Reckless's Avatar
Thanks John.....do you have any of the factory Fiero wiring schematics I asked about?
Old 02-27-2007, 05:31 PM
Speartech's Avatar
Like I mentioned, I have the factory service manuals but nothing in electronic format. Let me know if that's of any help.
__________________
www.speartech.com
Old 02-27-2007, 06:06 PM
Lincoln's Avatar
Some of these links might help.
http://home.att.net/~subzero350/index.htm
http://dtcc.cz28.com/
http://spad.sytes.net/fiero/manuals/
You can also find a lot of information on Pennocks Fiero Forum
http://www.fiero.nl/cgi-bin/fiero/Ul...i?action=intro
Old 02-27-2007, 07:11 PM
LSxChevelle's Avatar
Can I see some pics of the whole car?
Old 02-28-2007, 07:59 AM
Super Moderator
Reckless's Avatar
I will put up some more pics shortly.
Old 03-02-2007, 07:47 AM
Super Moderator
Reckless's Avatar
It appears we have finished what we need to do with the cradle. Since our engine came with all the rubber mounts still bolted to the engine, we figured out how to employ them. We have also torn down the engine for the heads and cam. Since this car will not use power steering, we will just gut the pump and use it as a pulley to maintain factory belt routing and length. The resevoir is eliminated.
Attached Thumbnails Our LS4/4T65E Fiero conversion-lambo-16.jpg   Our LS4/4T65E Fiero conversion-lambo-17.jpg   Our LS4/4T65E Fiero conversion-lambo-18.jpg   Our LS4/4T65E Fiero conversion-lambo-19.jpg   Our LS4/4T65E Fiero conversion-lambo-20.jpg
Our LS4/4T65E Fiero conversion-lambo-21.jpg   Our LS4/4T65E Fiero conversion-lambo-22.jpg   Our LS4/4T65E Fiero conversion-lambo-23.jpg
Old 03-02-2007, 08:45 AM
carado1984's Avatar
is it going to be a stock ls4?
Old 03-02-2007, 08:54 AM
Gen3Benz's Avatar
nice project!, ditto on the full car pics.
Old 03-02-2007, 11:14 AM
MstangsBware's Avatar
I just started looking into this motor/trans for my next swap into one of my Fieros. I just really started reading about what it takes to get rid of the DOD and what can be used to take its place. Will be watching this Thead for information on the install.
Old 03-02-2007, 11:24 AM
rat_rod_russell's Avatar
question is that a 60 degree bell housing on the ls4 block? dose it come in a manual transmission that you can run the linkage up to the front instead of out the back?
I want to put one or a Northstar in a Lotus Exige.
R^3
Old 03-02-2007, 12:01 PM
6camaro9's Avatar
Stephen,
take good notes... i'm wanting to do this too but i first have to find a 'GT. guess i need to get rid of my t-top or 3.4DOHC car first.
Old 03-02-2007, 02:34 PM
Originally Posted by 6camaro9
Stephen,
Yeah for me to start looking into this swap and even thinking about buying anything for it, I am going to get rid of my 5 speed 3800SC swap thats in my 88 GT. I have lost interest in it since I have the auto car and I know the 5 speed car will never compare. Reading all I can now about the swap and what it is all going to take, looks like its not going to be easy.
Old 03-02-2007, 10:48 PM
FIEROPHREK's Avatar
Talking WOOO HOO another fiero !
Please keep us posted on your progress ! I'm currently working on dropping an LS4 into my 85 GT. I'm tearing the motor down now to have it bored up to 5.7 specs and getting it ready for a cam/lifter/valve/spring swap. Here is a link to my teardown/build over at pennocks fiero forum. Oh and mustangsbeware you have a pm on pff.
http://www.fiero.nl/forum/Forum1/HTML/062546.html
These cars should scoot pretty good with this setup
Old 05-04-2007, 12:33 AM
Gen3Benz's Avatar
any updates?
TTT!!
Old 05-04-2007, 12:36 AM
fuel_junkie's Avatar
oh you *** lol , im picking up 3 feiro's here pretty soon, one to drop an ls1 in and fix up, one to build up into a kit car and the other just to take parts from....nice write up keep the pics commin!
Old 05-04-2007, 07:25 PM
Monza355's Avatar
do you have any measurements on the mounting points? also, stupid question but is the trans behind the motor when mounted in the car or in front. what side are the pulleys on?
bill
Old 05-07-2007, 05:00 AM
I havent seen any updates on this build in a while, is it still happening? I am working on mounting my setup to a cradle now but will be using an 88 cradle. Will be using the same method as above for the engine side but going with a differant setup for the trans. Going to use to mounting mounts for it instead of the single middle mounting point. Will all be mounted with poly mounts so there will be no give.
Old 07-07-2007, 09:23 PM
the_merv's Avatar
That little ****'s gonna scoot, how is it comin?
Quick Reply: Our LS4/4T65E Fiero conversion
