Nissan 240sx speedo
Old 02-27-2007, 08:31 AM
jsworkstd's Avatar
Default Nissan 240sx speedo
In the final stages of a LS1 S14 swap. Trying to make the speedo work.
I've got the Dakota digital signal conversion box that Hinson sells. Called them 3 times, no directions, promised to email.......
The Dakota box has instructions to hook up a single signal wire.
The Nissan S14 has 2 wires.
I searched couldn't find it.
Surely someone here has done it already?
Thanks
Old 02-27-2007, 06:13 PM
fouz65's Avatar
i dunno about the wires but s/1 here can help you. but this is what i think im going with.scan gauge . just maybe s/thing to look at.
Old 02-27-2007, 09:42 PM
Slo_240sx's Avatar
He can only use it if its 96 or newer. My speedo doesnt work either but I'm sure the DD will work. My tach work but jumps just a tad bit coming from 800RPM. Odd.
Old 02-27-2007, 10:09 PM
fouz65's Avatar
he can use that scaner on any ls1. no matter if its in a model-T. scan goes to the engine pc. nothing to do with the car. and ls1's are 98 and up (there is a 97 too i think, cant remember).
and the DD converter is $80. this gives you some more gauges for $170. and you cant ask for a easier install. plug it up to the obdII plug and done. some things will not work im sure like the fuel read outs. due to sensors in the gas tank not being there.
some other gauge read outs...
* Fuel Economy
* Fuel Rate
* Battery Voltage
* Coolant Temperature
* Intake Air Temperature
* Engine Speed (RPM)
* Vehicle speed (MPH)
* Manifold Pressure (not available on some vehicles)
* Engine Load
* Throttle Position
* Ignition Timing
* Open/Closed Loop
Old 02-27-2007, 10:35 PM
jsworkstd's Avatar
Thanks for the info. I've got eveything working except the speedo.
Don't want to add more gauges or spend more. Just want to get what I've got, which is supposed to work, working.
Thanks
Old 02-28-2007, 01:21 PM
natedawg's Avatar
i'd like to know how to do this too.
Old 02-28-2007, 08:35 PM
mmdb's Avatar
quick question is it difficult hook up a oil pressure gauge? I am getting mixed info and would like to know how you guys are doing it. thanks
Old 02-28-2007, 09:33 PM
datboibrad's Avatar
its nice but the display is to small for me. btw it doesnt really matter if the car is 96 or newer. you can wire the obd2 port off the ls1 harness, atleast thats what i did and my s14 is a 95.
Old 03-01-2007, 03:12 PM
jsworkstd's Avatar
So no one here that's done a LS1 swap into a Nissan has a working stock type speedo?
Old 03-01-2007, 09:32 PM
Slo_240sx's Avatar
Not a stock type no. Is that your LS1 Swapped S14? That thing looks sick, post some pics!
Old 03-01-2007, 10:43 PM
datboibrad's Avatar
pretty clean. needs a drop badly tho lol.
Old 03-01-2007, 10:56 PM
mmdb's Avatar
Looks nice Kinda looks like my car.
Old 03-01-2007, 11:23 PM
jsworkstd's Avatar
could be if you pay the bill
Old 03-02-2007, 10:55 AM
frankenstang's Avatar
More proof the guy in the post above never sleeps. I actually registered so I could laugh at his post. We were able to get the speedo kinda working. Need to finish tying up the wires and see how it goes. PM me or jsworkstd if you are interested in instructions once we can confirm it works.
Old 04-17-2007, 11:31 AM
natedawg's Avatar
i've looked into this more... summit is going to be handling this box soon looks like it will be price at $60.
i searched it and there was really good install on a s10. i just googled it. i'll try to find it and post the link for it.
Old 08-04-2007, 02:13 PM
natedawg's Avatar
anyone help me... with this?
i've got the 12v ignition
ground- to the chassis
vss- input from ls1
and then out to the 240 speedo
wont work.. anyone done this or can help me out here.
Old 08-04-2007, 02:28 PM
ronald so's Avatar
power, tap into any ignition power
vss in= get it from the ecu vss output to tach
signal ground, just ground to the chassis
output= goes into the f3 plug
I forgot what jumpers need to be changed.
Old 08-04-2007, 08:01 PM
natedawg's Avatar
let me go look at it again. only thing that might be different is i might have it in the other ground. since there's 2 in the dakota sgi-5 box.
Old 08-07-2007, 09:49 PM
natedawg's Avatar
okay, i have it in output 1 right now. and it still blinks green the whole time. The ls1 is 4000ppm coming from the ecu. what is the 240s speedo ppm? i did the preset where is does 2x the 4000ppm signal. i thought the 240 was 8000ppm i guess not though since it doesn't work. i called dakota and they weren't much help just said use output one and program it. what did u guys do to set it up?
Old 10-15-2007, 09:57 PM
natedawg's Avatar
bump my speedo still has not gotten fixed yet.
Quick Reply: Nissan 240sx speedo
