Anyone put an ls1 in early 4th gen f-body
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by swt94z28
trying to find out if and how easy an ls1 can be put into a 94 z28 6 speed. any knowledge will help.
sawzall wielding director
You will need the computer and harness, you will have to re-wire the harness a little bit to make everything function correctly. The K member is different, I`m not sure but the steering rack may be different, I know the v6 and LS1 rack is different. The T56 6spd is different between the LS1 and LT1 cars. The fuel system is slightly different, but you can use a vette filter/pressure regulator. There is a lot of info about the 4th gen LS1 swaps if you look around.
yea i got an ls1 in my 96 camaro, you gotta do a little wiring to get the pcm to work with the current body control module. Kmember, rack, steering shaft, computer, harness, tranny crossmember i cant remember all the little **** , throttle cable. I was fortunate enough to have a donor car. Car might be for sale soon.
Ryan
Ryan
I've got a 95Z with a T56.. as far as trans, what will I need to do to get an LS1 to match up? Also, I don't even have the bcm.. will this be a huge issue?
cost effective??? i was a able to do it for under $5k... and i sold my old forged rods/pistons, h/c Lt1 w/ computer, tranny and vig stall for $2400, so in reallity i spent under $2600 out of pocket cost
and thats with the motor, tranny and everything in it...
MMS stage 2 heads
mahle forged -4cc pistons
h-beam rods
all 3 wiringing harnesses (didnt have to do it but i got it at a goood deal)
ls1 gauge cluster
pcm
MMS 229 cam
New Yank pt4000
98 fuel tank (another one of those didnt have to but got it for $65 w/ the whole assembly)
k-memeber
ls1 steering rack (came with the motor)
ls6 intake
P&P tb
all the gaskets
all the machine work (ie, hone, degrease the block, turn the crank, balance the botttom-end)
98+ abs block
98+ front and rear brakes
98 BCM
fuel rail
valve covers
coil packs
all the AN lines and fittings for my fuel system (-6an line all the way from the tank w/ a russell in-line fuel filter)
think thats about it... the only reason i actually went thru with it was i got the long block for $500 w/ new yella terra rockers and a new billet U/D pulley, which i sold the U/D and rockers for $375...which came out to only $125 for the longblock![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
and actually had a lot of left over parts that i had 1 extra set of valve covers, coil packs, 2 extra coil pack harnesses, extra cam sensor, 2 extra fuel rails, and some bolts that i bought from the dealer, extra set of head bolts, and some other misc parts..
MMS stage 2 heads
h-beam rods
ls1 gauge cluster
pcm
MMS 229 cam
New Yank pt4000
k-memeber
ls6 intake
P&P tb
all the gaskets
98+ abs block
98 BCM
fuel rail
valve covers
coil packs
What don`t you have the BCM for? If you are missing the BCM from the LS1 motor it is not a problem, but if you are missing the BCM from the 95z you will be missing a lot of functions on the car. The LS1 motors will run without a BCM, most of the guys that put them into older cars get rid of the BCM.
