Gas tank for an A body?
It will fill, but i small trim of the frame rails (1/8-1/4") and either modify or build new straps. Sender will work, still 90ohms. You can either use QD for the fuel line, hard Line to AN or braze some AN fitting on the sender lines. I used a 99 Corvette filter/regulator.
You can see in my sig the setup I used.
If you can't find a Impala, you can check for Buick or other GM B body, they are the same.
If you need more info.. PM me.
Had the 502/TH400 in the car since 93' and tought it was time for a change. This year the car will only be running a small cam and will be tuned. Next year the package will reamain as is but with the addition of a couple of turbos. I am shooting for 500 rwhp or so with the stock internals.The following year it gets new pistons, rods, etc along with some L92 heads and 650rwhp +. I looked at the possible addition of a turbo, EFI and an OD trans with the 502 but went the LS route instead. It seemed to make more sense to me but some people will dissagree. I have had a couple of T Types in the past and love the power and torque of a turbo(s). When I put the 502 in the car my attitude was a Chevelle HAS to have a big block. As I got older my idea of a cool street car seems to have changed a little just like my taste in beer! Dont get me wrong, a loud, pissed off big block with a carb is awsome but my tastes have changed with time. I like the idea now of some stealth and being able to sneak up on someone!
I kinda wanted an intank pump. I didn't really want to trust an inline pump, and I assumed sumping, baffling and stuff to the original tank would be too difficult, although I don't really know what is involved. I should do a search on that...
Is there anything wrong with aluminum tanks? I could always make an aluminum one at work... idk...
