LSX fox headers
Old Apr 4, 2007 | 10:49 PM
stang50bangerz's Avatar
Default LSX fox headers
which to use and what kmember for clearences thanks
Old Apr 7, 2007 | 12:29 AM
99ta's Avatar
Has anyone ever tried Mac mid-length headers for this swap? I've been wondering if these will work.
Old Apr 7, 2007 | 02:31 PM
vanilla89's Avatar
Old Apr 7, 2007 | 05:02 PM
99ta's Avatar
Originally Posted by vanilla89
Already tried...
Old Apr 7, 2007 | 05:13 PM
PRAY HRD's Avatar
most have used the mac 351w/fox swap headers. for a k-member, try either the aje lsx/fox swap k' or any 4.6/fox swap k'. if you search under mustang, notch, notchback, you should get a TON of info, but you have to read it to find it, it is there! hope that helps. oh, and don't quote me becuause i didn't build mine and i could be completely wrong.
Old Apr 9, 2007 | 12:25 PM
1point3liter's Avatar
I don't have a fox, but am wondering if the ls1 rx7 longtubes will fit. They are built to sit very close to the motor and trans.
They can always be resold if they don't work.
https://shell7.tdl.com/~jags/Mazda-R...-V8_Order.html
Old Apr 9, 2007 | 12:28 PM
Also,
If they haven't already been tried, I'm sure someone that has them can take some measurements for you.
Old Apr 27, 2007 | 01:10 PM
LSxChevelle's Avatar
I like they way the headers hug the motor. Definately interested in seeing if they fit...
Old Apr 27, 2007 | 01:26 PM
1 BAD GM's Avatar
How much do those LS1 RX7 headers cost? Those look like a good alternative especially since I am going to run a motorplate and don't have to deal with the motor mounts getting in the way.
Thanks,
Chris
Old Apr 27, 2007 | 02:04 PM
Mr. Hyde's Avatar
It's not the motor mounts that are usually the issue, it's the steering shaft. With my setup, no matter how close the front tube could've been to the block, it would not have cleared the steering shaft.
Old Apr 27, 2007 | 03:14 PM
1 BAD GM's Avatar
Understood, however I would rather have to modify one or two primaries to go around the steering shaft than cut the whole flanges off, reshape the primaries on the 351 headers to fit the LS1 oval flanges and then probably have to modify them even a little more than that.
Chris
Old Apr 27, 2007 | 04:16 PM
Mr. Hyde's Avatar
I hear ya on the cutting 1-2 tubes vs swapping flanges and all that jazz. I found that many of the headers that looked like they would fit close (C5, GTO or even 1st gen camaro swap headers from hooker) were $500 and up, whereas the Pacesetters only ran me $290. And even then mine ended up as you see in the pics from the other thread because we decided to go equal-length. Heh, I can really only tell you what didn't work anyway since I'm definitely no engineer
Old Sep 9, 2007 | 03:09 AM
jfman's Avatar
Might sound stupid but can you use the STOCK ls1 exhaust manifolds?
Old Sep 12, 2007 | 11:56 PM
jfman's Avatar
Old Sep 15, 2007 | 12:48 AM
jfman's Avatar
Old Sep 15, 2007 | 10:38 AM
lt4malibu's Avatar
if you use the AJE SBC k-member, its as easy as a phonecall to KOOKS
Old Sep 15, 2007 | 10:53 AM
AnDy R's Avatar
those rx7 ones run about 700$ from jtr (jagsthatrun)
Old Sep 15, 2007 | 03:34 PM
NoRotor88's Avatar
Try some BBK 1 3/4" 5.0 long tubes. Cut the head flanges off and weld the LS1 head flange on. I did this as a cheap way to put long tubes on my RX7. Fits great and I would think it would work in a Stang. Cost me about $300 before coating them.
Jesse
Old Dec 6, 2007 | 01:46 PM
72Elkytpi's Avatar
where did you buy the LS1 head flange to modify your headers.
thanks
Old Dec 6, 2007 | 02:13 PM
vanilla89's Avatar
SDPC has them or you can get them at any dealership
Wow this thread is 8 month old...
