1965 chevelle wagon ls1 conversion
Old Apr 20, 2007 | 12:28 PM
Elec87's Avatar
Default 1965 chevelle wagon ls1 conversion
Started the ls1 conversion in the bosses 65 wagon this week we only got to work on it for two days but are excited about the progress.
Problems so far:
Oil pan (custom canton) does not clear Chassis
Column shifter linkage may be tricky
headers for the application are taping the floor board.
here are some progress pics!
Old Apr 20, 2007 | 12:39 PM
SUPERWAKE502's Avatar
Nice job, What size carb did you go with?
Old Apr 20, 2007 | 12:58 PM
Elec87's Avatar
650 quickfuel, the engine dyno'd at 385 with a stock cam and the same headers.
Old Apr 20, 2007 | 02:48 PM
ryanvv355's Avatar
Thats gonna be a nice ride, keep us up to date. I love wagons!
Old Apr 20, 2007 | 03:35 PM
Elec87's Avatar
It needs some paint work and a few things still, it's a fun project.
Old Apr 20, 2007 | 03:40 PM
67rsss's Avatar
Keep up with the pics, It looks like it will be a nice install when it is done. Interested in how you wook up the heater hoses. I don't know if the top or the bottm of the heater core is the input. When it is all done, you should post the fuel economy numbers as well. What trans did he decide to use? For the pan, Street and Performance does offer one that clears the linkage. On the linkage, it looks like Lokar will be your friend, they make or can make a way to shift anything. What headers are you using?
Old Apr 24, 2007 | 09:15 PM
Motivational's Avatar
[B][I] Nice car. I have a 65 SS Convertible Chevelle and am thinking about doing a conversion. What kind of motor mounts are you using and what have you done to the crossmember?
Old Apr 24, 2007 | 11:39 PM
G-Body's Avatar
sawzall wielding director
The bottom hose on the heater core should be the input, that way if there is air it will naturally rise to the top and out of the heater core.
Old Apr 25, 2007 | 08:38 AM
67rsss's Avatar
THanks G-Body, I was concerned that GM changed the connector sizes over the last 40 years and I was going to connect it backwards!
I would love to see this wagon in person. The Mrs. doesn't like wagons, but there are a few pretty cool ones out there, and I always enjoy seeing them....
Old Apr 25, 2007 | 09:49 AM
chree's Avatar
Wagons rule!
Old Apr 25, 2007 | 06:10 PM
lt4malibu's Avatar
http://www.chevelles.com/feature/september2004.html <my dad's chevelle...
been trying to talk him into bigger wheels and rear disc's and EFI...
Old Apr 25, 2007 | 06:23 PM
Lane's Avatar
Nice!
Old Apr 26, 2007 | 11:44 AM
TT402LS1's Avatar
Did you have the oil pan custom built, or did you by their swap pan? I had them build me a custom pan that holds 6.5 qts.(not the swap pan on their web site). The one on their web site was my first design that didnt hold enough oil and the front corners of the sump touched the engine crossmember.
I also noticed you are from Davenport, Ia. I live just on the other side of Dubuque, Ia in WI.
Love the project! Keep us informed.
Ron
Old Apr 26, 2007 | 12:15 PM
steady01's Avatar
niceass set up
Old Apr 26, 2007 | 12:16 PM
steady01's Avatar
Default nice car
nice *** set up
Old Apr 26, 2007 | 06:32 PM
WagonCrazy's Avatar
Yeah, me too. Wagons rock. Specially them old ones with modern drivetrains.
Old Apr 27, 2007 | 11:31 AM
curlyws6's Avatar
Hopefully within the next few years, I will get my hands on a '64 Chevelle and I plan to do a LS1 (fuel injected) / T56 transplnt into it.
Sweet ride!
Old May 18, 2007 | 09:42 AM
dickey P's Avatar
sweet ride
I HAVE A QUESTION HAVE YOU RUN INTO ANY PROBLEMS WITH THE PASSENGER SIDE TIE ROD THAT CONNECTS TO THE DRAG LINK HITTING THE OIL PAN ? I AM DOING THE SAME SWAP INTO A 66 AND NOW I CANT TURN RIGHT
Old May 26, 2007 | 12:12 PM
WILWAXU's Avatar
Cool Car! The air cleaner is icing on the cake
Old May 26, 2007 | 05:56 PM
SMAX's Avatar
very nice. i am swapping a heads, cam, carb ls1 into a 65 el camino.
i went with the
hooker headers
hooker mounts
moroso oil pan
