The LSZ project begins!
Old Apr 23, 2007 | 04:17 PM
300zxls1's Avatar
Default LS1 300zx swap BEGINS!!
Well ending up deciding to dump the RB30 swap in the 300zx and go with a LS1. I had origonally planned for the inline 6 swap and basically building a street car. But I ended up selling my current time attack project a 951 GT3 Widebody to a friend. Then I decided I wanted to do something a little different and build a time attack single turbo LSZ. I need something to compete with my buddies new car. As of right now it is gutted as you can see it will be getting a complete cage with nascar style door bars. Just got the mock up block in. Most likely I will be running a vette pan and cutting the firewall and trans tunnel alot. I will be shooting for 50/50 balance and the firewall will pay the price. Not sure as of now if I will be running motor plates or standard motor mounts and modding the crossmember. All depeneds on how the pan fits once I get it and how far back the motor will need to sit. Should be getting it into the shop within the next 3 weeks. Besides mounting up the engine and cage we will be mounting the 15g fuel cell in the spare tire cut out. We will be tying in weld in sub frame connectors also. Here are some pics of the progress so far just been gutting it and getting ready for the cage. Sorry for the crappy pics but the garage is really small. Also should be pressure washing the engine bay soon dont worry. Should have updates soon hopefully. And yes I just sat the block in there and if you notice it is balancing on a gallon of juice.
All types of room to breathe.
Heres the old time attacker. It went to a good friend and he will be doing complete 968 drivetrain and turbo sometime soon. The LSZ will be getting a very similar cage.
Old Apr 24, 2007 | 12:35 AM
XofXtimeX's Avatar
Bad *** man. Just yesterday I was talking to my friend about wanting to try a LSX swap into a Z after I do my 240. Will be ******* nice to watch your car come along. I can't wait to see this outcome
Old Apr 24, 2007 | 02:47 AM
98darkbird's Avatar
Yes and YEs...hahahah think I am going to do a s14 240 swap..work out all the bugs, then probably sell it and do a 300 swap. For buget purposes I say go Iron 6.oL, L92heads/ L76 intake manifold, single turbo think around a T76 would work great and have little lag. You can flip the truck manifolds and just make a basic crossover pipe. ULTRA DIRTY good luck
Old Apr 24, 2007 | 05:11 AM
300zxls1's Avatar
Thanks man I was going to do a S13 swap before I picked this Z32 up for cheap. I wont get to pick up the motor and trans for awhile but hopefully it will be aluminum when the times comes. But that def would save me some cash to go iron. I am planning on a simple flipped truck manifold setup and a t76 would probably be sufficient.
Old Apr 24, 2007 | 06:24 PM
dotstereo's Avatar
Best of luck with this swap! I'm really interested to see how it turns out. If you haven't seen the other threads about this, search and you'll find a few posts I've made that round up most of the Z32/ lsx swap info.
Old Apr 24, 2007 | 08:43 PM
300zxls1's Avatar
Thanks man it should turn out pretty good and I should have the cage and fuel cell dont with 8 weeks. It will be tight to find time to get it done but it will happen. I have done alot of research to aid in the swap going as smooth s possible. I will have updates soon.
Old Apr 24, 2007 | 08:47 PM
THE_SUPRA's Avatar
so freakin cool!! that think will be crazyness!
what is the estimated curb weight, if you dont mind?
Old Apr 24, 2007 | 09:06 PM
Gen3Benz's Avatar
Seems like this swap has been done with front and rear sump pans.
https://ls1tech.com/forums/showpost....3&postcount=11
Push the rear sump far enough back to clear the steering......or
Put on a front sump pan and relocate the sway bar, maybe not but that space doesnt look big enough.
Are you gonna try something different?
Will be a sweet car when done.
I cant stand working on nissan motors, but 300/350 z's handle nice.
Old Apr 24, 2007 | 09:12 PM
300zxls1's Avatar
Real skeptical right now on the weight. I am hoping for under 2700lbs. I feel it is very doable. Stock weight is 3219 and the swap will lose a little weight over the iron v6. I also am loosing all the interior running sheet metal dash and 1 kevlar carbon seat. Removed all the sound deadening and it weighted in at 70lbs. The stock dual exhaust is crazy heavy. Plus the heat and ac assemblies and the door glass and power window assemblies. Also there was about 130lbs in wiring harness and modules removed lol. I dont see any reason the car wont weigh in at 2700 dry as long as the cage dosnt go to crazy. Thanks
Old Apr 24, 2007 | 09:15 PM
300zxls1's Avatar
I will be doing a different setup than anyone else has done. Sense this will be a caged track car and has no street or daily driver limitaions I will be doing alot more cutting than all the others. I am shooting for 50/50 weight. I will be cutting the firewall and trans tunnel alot to get the motor back. I will be running a rear sump pan. I may end up running motor plates depending on how far back the engine ends up sitting.
Old Apr 24, 2007 | 11:44 PM
dotstereo's Avatar
The white z that was done (krazeezx) mentioned his weight distribution was around 50/50. He massaged his firewall a bit, but it seems you are less restricted as far as how much you will cut. I should think weight distribution will not be a problem.
Old Apr 25, 2007 | 08:11 PM
300zxls1's Avatar
Thats the plan.
Old Apr 26, 2007 | 12:34 AM
THE_SUPRA's Avatar
again that thing will be a hoss!
what are the specs on the motor? forged internals and a big snail?
Old Apr 26, 2007 | 08:12 AM
300zxls1's Avatar
As of right now the plan is a stock LS1/T-56 and a S80 on tubular manifolds. Then put all the rest of the money into suspension and brakes. Then once it blows do heads cam, intake and a forged shortblock.
Old May 22, 2007 | 03:34 PM
300zxls1's Avatar
Well I finally got it into the shop last week and got to work on it a little. Finsihed gutting the doors and started to mount up the fuel cell in the spare tire cutout. I wont get to touch it until middle of next week. But then I should get a good 3 weeks work in. I will get some update pics once it is worth while. I ended up picking up ls1 intake and a t-56 case and vette pan to aid in the mock up. I have decided to run motor plates sense the motor will be sitting pretty far back. It appears I will be cutting up the firewall like I had planned to get the weight distribtion desired. Again this car is being built to compete in Super Production and or ITE so I dont have many restrictions. I will keep everyont informed. Thanks
Old May 22, 2007 | 03:43 PM
NemeSS's Avatar
y is the mock up block facing in the wrong direction?
the "distributor hole" is facing forward.
just asking if theres a reason u are lining up the engine that way
Old May 22, 2007 | 05:03 PM
300zxls1's Avatar
lol Sorry about that I just set it in there to take a pic. Dont worry I will flip it around before I mount it up.
Old May 22, 2007 | 05:56 PM
dotstereo's Avatar
When you say you've found a Vette pan, do you mean the C5 batwing pan, or are you using a C6 pan?
I don't know if you saw it but a few weeks ago there was a Z32 for sale on ebay with an ls1 swap in it. It's interior was gutted and it was a track car, I think it was pretty light? I wish I could remember more about it/ find a link.
Old May 22, 2007 | 07:16 PM
300zxls1's Avatar
I am talking about the batwing pan and no I wish I had seen it on there. I havnt even seen anyother gutted Z32's with Ls1's
Old May 23, 2007 | 04:41 AM
Race300's Avatar
here is a link to my car https://ls1tech.com/forums/showthrea...ight=300zx+ls1 gutted z32 with ls1 its a 2+2 so you will probely have a even lighter car i will try to get some new pics on the changes i made fore this year ...
good luck with the nice compination of car /engine ....
