LS1 A/C on first gen camaro ....how to?
Old Sep 14, 2009 | 04:31 PM
69 Ghost's Avatar
I am using the BRP setup with the notched frame. The compressor is the stock LS compressor and the rest of my system is a stock vintage air. I have not charged it up yet or hooked up the harness but is supposed to be a one wire hookup for the A/C request just like any other fuel injection unit. I believe you should be able to use the stock pressure sensor but you may have to use the factory one which may mean some welding or something. The difference may be in that the Vintage is a on off pressure switch and the factory is a pressure sensor that is used to adjust the pressure. The rest is the stock PCM wiring for the compressor. It is a fallacy that the variable compressor will fail and should work better due to it not having an on and off surge. In fact if you are afraid of that you can convert it to a fixed style compressor like the Sanden style just do a search on this site. You can use a block adapter to tie in your Vintage hoses. I got mine from Doc's Blocks and used the vertical adapter AA0338. This is less than $25. The fit is a bit tight but it does fit.
Old Sep 14, 2009 | 04:40 PM
ssduane's Avatar
I've spent a lot of time talking to Hot Rod air and Vintage about the compressor issues. HR says to use the LS compressor because its a varibale displacement compressor and will limit cooling and not ice up the condensor from overcooling, they do not recommmend the Sanden unit. VA recommends using the Sanden and not the LS comp, but their manual also states that if air flow reduces from the cooling unit to adjust the temp switch because the unnit might be icing up. So looks like botha re in agreement ont he compressor issue, but VA doesn't recommend it, though they do make a bracket for it.
Old Sep 14, 2009 | 04:45 PM
69 Ghost's Avatar
Sorry I believe it is the AA0443 adapter. Here is the link I talked about
https://ls1tech.com/forums/conversio...ble-fixed.html
Old Sep 15, 2009 | 12:32 PM
S10xGN's Avatar
I realize this thread is old, but my info may help some others. S&P makes a bracket kit that uses a Sanden 508 (in the somewhat stock location), but moves it inward about 3" and forward enough to use the front grooves in "single belt" mode. It's not cheap, but looks good and gets you some needed clearance. Here's a pic of my setup, the pulleys were milled and painted and the brackets were glass-beaded to look stock.
Old Sep 15, 2009 | 04:48 PM
Blue67LS2's Avatar
I like the way this looks. I assume you have to run a 508 with rear line provisions? Do you happen to have a part number or any additional information on the bracket. I have done a fairly exhaustive search, but I have never seen this one before. Also, how much is expensive?
Thanks!
Old Sep 15, 2009 | 10:41 PM
S10xGN's Avatar
Thanks!
Mine frame has enough room for the side exit ports. I looked up my invoice, it was $318.75 back in 2006 (w/o the compressor). I can't link you to the exact page because of how S&P's catalog works, but you can find page 81 and look at the pic in the upper RH corner. You'll get the belt and everything to the left of it.
Old Sep 16, 2009 | 08:02 PM
Blue67LS2's Avatar
Russ, thanks for the information. I should be able to track it down from here. Nice looking ride by the way.
Old Sep 16, 2009 | 09:27 PM
matt1976's Avatar
I have been told that Southern Air makes an ac system that is designed to work with the ls compressors. Anyone used one yet? And Geezer where did that outside the valve cover bracket come from? That looks to be the answer, move the AC comp and keep the rest stock.
