Wiring and VAC diagrams for LS1 (2002 camaro)
Sorry for such a basic question as they probably are out there but I just got my engine and right now. What I'm looking for is a diagram showing where all the vacume lines are on the engine and what they are for. Also the electrical connections. I've found a lot of wiring info but no diagrams showing where on the engine everything is.
Suggestions on what is the preferred repair manual would be helpful as well.
Thanks
Thaniel
Thanks
Thaniel
Originally Posted by Schitzo
Hi thaniel, buy a haynes manual for 98+ F-Bodies. That is what I did for my swap. It has wiring diagrams and shows pics and locations of connectors on the engine.
Otherwise hit your public library and check out the Mitchell online database.
Well I bought the haynes manual. The one I ended up covers the 93+ and I must say I get reall tired of seen 4 different engines for everything. Interestingly enough the book is just as thick as the Haynes maxima manual which only covers 1 engine. Didn't really show me what I wanted so I went back to the web. Found this:
http://www.v8rx7forum.com/v8-rx7-tec...ls1-parts.html
Shows exactly what I was looking for. Perhaps someone else needing the same info will find this.
