Any 4.8L?
Old May 13, 2007 | 08:56 PM
ZROCWS6's Avatar
Default Any 4.8L?
Curious if anyone had done anything with the 4.8L engine? My buddy's RST Silverado has that engine and it sounds sooo nice and different.
Old May 13, 2007 | 09:52 PM
Kenova's Avatar
I have one in my '05 standard cab long box. I haven't done anything to it, and probably won't, but it is a very impressive little engine. It loves to rev and my wife still hasn't got the hang of driving it without sqwaking the tires.
If it were in something lighter I'm sure it would really come alive with a mild cam.
Ken
Old May 13, 2007 | 09:55 PM
ZROCWS6's Avatar
Yeah I have been really wanting to start a V8 swap into an FD RX-7 and thought about using the 4.8 instead of an LS1. It can be an exotic looking car and the smaller displacent of the 4.8 would be a nice sound to go with it!
Old May 14, 2007 | 07:46 AM
patgizz's Avatar
and they can be had for $200-300 if you know where to look.
Old May 16, 2007 | 11:31 PM
sleepybu's Avatar
where dose one look
Old May 16, 2007 | 11:43 PM
camarokid94's Avatar
my buddie just put one in his 2000 S-10. i did my part as well sellin him my old LS6 intake CHEAP and hookin him up with all my old spare parts. should be cool. this weekend ill be tuning it with my HP tuners.
Old May 17, 2007 | 06:25 PM
ZROCWS6's Avatar
a 4.8 engine for $200-300? Where?!
Old May 17, 2007 | 06:40 PM
crainholio's Avatar
I just wrecked my '02 Silverado back in March in the central NJ area, it had a 4.8L in it that was babied its whole life. Amsoil for its first two years, then German Castrol Syntec right up until the wreck.
Some lucky guy is going to score big at whatever junkyard the truck went to.
Old May 21, 2007 | 04:10 PM
RacnJsn95's Avatar
I bought my 4.8l for $354 shipped (and $250 of that was shipping!) off ebay. I plan on using a 5.3 crank & rods, with the 4.8 piston because they are flat tops, where the 5.3 pistons are dished.
Old May 21, 2007 | 06:31 PM
ZROCWS6's Avatar
WOW that is cheap!! What will the 5.3 crank stroke that out to?
Old May 21, 2007 | 06:37 PM
wolfy's Avatar
i think that makes it a 5.3 with a higher compression ratio...
Old May 22, 2007 | 04:34 AM
RacnJsn95's Avatar
Yeah, just a high compression 5.3. Stock they're both supposed to be at 9.5:1, they had to dish the 5.3 pistons to keep it there... My rough calculation shows that The 4.8 w/ 5.3 crank & rods (OR 5.3 with 4.8 pistons) will be around 10:1 - 10.75:1 assuming the head gasket is .040 compressed. The only think I don't know is the deck height, so Assuming the pistons is .030 down in the hole at TDC the compression will be closer to the 10:1 side. If it's 0 at TDC, it will be more towards the 10.75:1 side.
Like I said, Rough calculation. Keep in mind that's just Static Compression ratio; throw a big cam in there and that will soak some of it up.
Old May 22, 2007 | 01:43 PM
NemeSS's Avatar
4.8/5.3 use the same block
different cranks and set of rods
conventional 3.622 stroke found on 5.7/6.0 also used in 5.3
different balance.
rods for the 5.3 are same as 5.7/6.0 6.098 length
4.8 uses 3.268 stroke crank along with 6.276 length rods
piston diameter for both the 5.3 and 4.8 are 3.876
with compression height of 1.338 +/- .001
ls series deck are 9.240 for all stock blocks
pistons used in 5.3 have a slight spherical dish at about 5cc's
4.8/5.3 blocks have been know to be overbored up to .125
to displace 346-347ci with 3.622 stroke crank
basically a iron 5.7 ls1
i have the machined 3 blocks for this application.
