manual lq4?
Old May 18, 2007 | 10:06 AM
Black.'s Avatar
Default manual lq4?
are there any manual trannies that'll mate up to an lq4? or l92?
Old May 18, 2007 | 10:41 AM
BLWN1's Avatar
LQ4 is the low compression motor isnt it? Mine was a 5 spd motor out of a work truck.... if that helps?
Old May 18, 2007 | 11:27 AM
speedyhawk101's Avatar
I believe that the T-56 will bolt up. I've seen 6.0 cast iron blocks that maintained the T-56 after the engine swap. Should just bolt on...... I could be wrong
Old May 18, 2007 | 11:55 AM
12secSS's Avatar
Any trans that will bolt up to an SBC can be made to bolt up to a Gen3/4 engine. If you want the easiest to mount setup, go with a 2001 and newer LQ4 with an LS1/6/7 clutch kit (flywheel, clutch, pressure plate), using a 1998-2002 F-Body T56.
Old May 18, 2007 | 01:45 PM
9540x's Avatar
lq4 is the same as any other LSX based engine. t56 will bolt right up
Old May 18, 2007 | 02:35 PM
NemeSS's Avatar
t56 will bolt up, but must intall pilot bearing.in the crank
also lq4/lq9 engines that came with a 4l80e have .400 offset flexplate,
which they use a spacer on the crank before the flexplate.
this spacer and flexplate will allow the use of a 700r4/th350 or th400
gm chevrolet trans witha 10' convrter.
Old May 18, 2007 | 06:49 PM
Black.'s Avatar
cool thanx guys. t56 here we come!!!
Old May 18, 2007 | 09:39 PM
fullthrottledan's Avatar
I currently have a t56 behind a lq4. works very good.
