What brand of Hose end fitting is this?
Old May 20, 2007 | 07:30 PM
Thaniel's Avatar
Default What brand of Hose end fitting is this?
Can anyone recognize what brand hose end this is? I would like to change the length of the line. From what i have read the same brand line is required (or at least recommended). I've searched the net but can't find what it would be.
Any help would be great.
Thanks
Attached Thumbnails What brand of Hose end fitting is this?-153-5324_img.jpg
Old May 20, 2007 | 07:50 PM
xssive's Avatar
Looks like an Earls power steering or industrial fitting
Old May 20, 2007 | 08:08 PM
Thaniel's Avatar
Really think it's an Earls? I the few I found pictures of earls and the had earls stamped in them. But what do I know? I'm new to the reusable fittings for braided hose.
Oh the symbol on the side looks like a "G" but the tail on the G is like an arrow.
If it helps the fitting itself is on a clutch line that was made by someone else to adapt to the T56 trans slave. So the line. SO I believe the line is a teflon coated line.
Old May 20, 2007 | 08:45 PM
mattmartindrift's Avatar
shouldn't matter. As long as you get the correct size teflon-lined hose, and a replacement ferule if it was any material other than stainless steel.
Old May 20, 2007 | 09:47 PM
xssive's Avatar
Oh try Goodridge then...
Old May 20, 2007 | 11:23 PM
firefighter's Avatar
Gates industrial stuff?
Old May 21, 2007 | 11:21 AM
Thaniel's Avatar
The difficulty I am having is finding out what markings those companies have on their parts. Anyone know?
Maybe I'll just try a line and see if it will fit. Hate to go that way but if it works....
Old May 21, 2007 | 05:14 PM
line/fitting manufacturers usually manufacture to a standard, most likely a mil-spec.
Old May 22, 2007 | 12:42 PM
Thaniel's Avatar
And the prize goes to xssive. It's Goodridge. At least thier symbol is identical to the one stamped in the fitting.
