Plugging Oil Pressure Switch
Old May 21, 2007 | 02:21 PM
Glenntx's Avatar
Default Plugging Oil Pressure Switch
My oil pressure switch, located on top of the rear part of the block, has started leaking oil thru the electrical plug. Since I'm not using it, can anyone tell me what size and thread type plug I can use to plug it? I'm hoping to grab something in town today and repair it this evening and i don't have the jeep with me.
Thanks in advance.
Old May 22, 2007 | 01:10 AM
bczee's Avatar
Using the search function... It has been posted a few times as being 16x1.5mm, they also make adapter from 16x1.5mm to 1/8"NPT.
Searching works great..!
Old May 22, 2007 | 09:22 AM
Glenntx's Avatar
I did search, found nothing, but thanks for pointing that out. I guess I'll begin every post with "I've searched and found nothing, here's my question..."
Anyway, thanks for helping me out.
Old May 22, 2007 | 01:15 PM
bczee's Avatar
You just need chose your search word better.... "oil pressure threads" worked for my search..
Old May 22, 2007 | 06:15 PM
Sabre002's Avatar
that same size dran plug works great most parts stores will have it.
Old May 23, 2007 | 10:36 PM
Glenntx's Avatar
Thanks Sabre. All the parts stores so far don't have a 16x1.5 pipe thread plug, is a drain plug different?
BTW, how are things in Myrtle Beach? Had the time of my life there about 8 years ago.
Old May 24, 2007 | 06:04 AM
LS1MCSS's Avatar
Order the part on this link and it will have the correct adapter. I used one to move my oil pressure sender to the top of the engine. http://www.autobarn.net/eqoilpreselt.html
Old May 24, 2007 | 09:47 AM
bczee's Avatar
Yes, you will be able to use a drain plug if it is the correct thread size.. (you won't need one of those adapters if your just plugging it), just make sure that it seals or using some teflon sealing tape on the plug.
