Pics of my swap
Old May 24, 2007 | 11:57 PM
blahster's Avatar
Default Pics of my swap
http://blackshadowz.cz28.com/LS1Swap/100_0868.JPG
http://blackshadowz.cz28.com/LS1Swap/100_0869.JPG
took a few pics of my swap completion...YAY!
and here are some in progress pics....
http://blackshadowz.cz28.com/LS1Swap/100_0830.JPG
http://blackshadowz.cz28.com/LS1Swap/100_0845.JPG
http://blackshadowz.cz28.com/LS1Swap/100_0846.JPG
http://blackshadowz.cz28.com/LS1Swap/100_0847.JPG
http://blackshadowz.cz28.com/LS1Swap/100_0848.JPG
http://blackshadowz.cz28.com/LS1Swap/100_0849.JPG
http://blackshadowz.cz28.com/LS1Swap/100_0850.JPG
and some overall pics....
http://blackshadowz.cz28.com/LS1Swap/100_0877.JPG
http://blackshadowz.cz28.com/LS1Swap/100_0880.JPG
http://blackshadowz.cz28.com/LS1Swap/100_0874.JPG
http://blackshadowz.cz28.com/LS1Swap/100_0875.JPG
http://blackshadowz.cz28.com/LS1Swap/100_0876.JPG
Old May 25, 2007 | 01:04 AM
fuel_junkie's Avatar
very clean swap, nice!
Old May 25, 2007 | 08:40 AM
PRAY HRD's Avatar
mean looking car man, nice job!
Old May 25, 2007 | 08:47 PM
Stu Cool's Avatar
Way to go, looks good!
Pat
Old May 25, 2007 | 09:07 PM
ONEBADASSWS6's Avatar
Nice work man
How's she run??
Old May 25, 2007 | 09:22 PM
daniel6718's Avatar
so you didnt get any of the factory gauges to work? what did you do or a fuel system? i saw you had stock ls1 lines....who did the wireing?
Old May 25, 2007 | 11:03 PM
blahster's Avatar
The factory gauges that work are the Oil pressure, amps, and speedo, tach works but is off....
i replaced the LT1 fuel system with the LS1 system...the whole thing, lines, tank, etc.
I did the wiring myself...just gotta hook up my carbon fiber gauges now....
Thanks for the complements! and i just put on a Xenon body kit too..so it looks even better now! lol!
Old May 26, 2007 | 02:33 AM
daniel6718's Avatar
you didnt get the stock gauge to work with the ls1 tank did you?
tach just needs to be tuned...send it to pcm4less.com
Old May 26, 2007 | 10:09 AM
Ls1Bait's Avatar
I love when lt1s have ls1s inside. I like the swap....
Old May 26, 2007 | 10:41 AM
95formulalt1's Avatar
can you feel a dif in the Ls1 compared to the LT1? i am doing the same thing right but with a 95TA.
Old May 26, 2007 | 05:55 PM
blahster's Avatar
Holy crap...there is NO comparison between the two engines...the LS1 feels so much...looser than the LT1...in a good way...as in it breathes harder, just overall feels way faster... i have to be careful when i leave a corner otherwise i send it sideways...at half throttle! lol!
Yeah. It's great. I Love it!
Old May 26, 2007 | 08:35 PM
the_merv's Avatar
Nice job.. alot of work went into that. It's tight in there too..what did you base the Wiring off of to do your Harness?
Do you plan to take the EGR stuff off of it?
The Tach can be fixed, that is not that hard to do. I got a guy that Tunes with EFI Live, he did it with that program.
Old May 26, 2007 | 08:41 PM
blahster's Avatar
i based the wiring off the stuff from shbox.com for the 95 wiring and then this forum for the 99 wiring...
Just gotta get my fuel level to read what it's supposed to...
Old May 26, 2007 | 08:58 PM
the_merv's Avatar
Well the LT1 Fuel System is pretty much an independent system, just like the Cruise Control. All you got to do is get the Relay Wire and the Ground Wire to the right spots, and it's good.
I know you said you switched to the LS1 Fuel System, and that one I believe has the Fuel Level as a Signal Wire from the Sender to the Computer. From there is sends a Signal to the Guage Cluster. How is it reading?
Old May 26, 2007 | 09:00 PM
blahster's Avatar
i wired it as the LT1 was wired and the gauge reads way beyond full....lol. guess i should wire it to the computer...??? i have an autometer fuel level gauge i was just gonna hook up...but i dunno if it will work or not...
Old May 26, 2007 | 09:11 PM
the_merv's Avatar
Sounds like the Gauge is spiking cause it's grounding out. Does it even move, or is it like this constantly?
Old May 27, 2007 | 12:13 AM
blahster's Avatar
constantly...i thought it would be because it might be getting TOO much power...but i dunno...i'm gonna hook my autometer up sometime and see what it reads.... if nothing else maybe i can devise a signal converter....
Old May 27, 2007 | 12:31 AM
how many hours do you have it to it? i cant wait till my car is all done..
Old May 27, 2007 | 01:43 AM
the_merv's Avatar
K.. it's doing what I was thinking earlier. The LT1 Fuel Gauge works like all the old cars, there is a Hot, Ground, and Signal Wire. The '99 up LS1 has a Wire that comes from the Sender and goes to the Harness, to the Computer, and then out to the Gauge Cluster at the Fuel Level Wire.
If you un-plug or cut out the LT1 Wires, it is probably not getting any signal, and saying it's full all the time.
Old May 27, 2007 | 04:40 AM
ex-SS-ve's Avatar
i know exactly what you mean! i did some bolt ons ,heads/cam/intake and its not the same car as my old 383 ltx setup. took it to a local car meet. should of seen the dumbfounded looks on peoples faces..
