We are in trouble!!!!!!!
Old Jun 9, 2007 | 07:13 PM
67rsss's Avatar
Default We are in trouble!!!!!!!
[This problem has been resolved by a very understanding seller that backs up his warranty with no arguements. Thanks to Lynn at Performance Auto in SC]
Well, we tried to fire our LS1/T56 swap today and discovered something bad. We hadn't realized that in shipping the sheetmetal cover on the computer was crushed in. Turns out there is not a lot of clearance between that cover and the pins on the circuit board. Arc, spark, toast. Ran to an automotive recycler before he closed and bought a used PCM out of a van for $90, and spent the last several hours swapping parts over to our PCM. No joy. Sad moment right now, feel like we have been stabbed in the chest.
We now need HELP! What is the fastest (within reasonable cost) way to get a PCM setup for an 02 F-body harness with the following done to it:
VATS disabled
Skip shift disabled P0803
Rear O2's disabled P0137, 138, 140, 141, 420, 157, 158, 160, 161, & 430
Air Pump disabled P0410, 412, 418, 1415, 1416
EGR? P0400, 401, 404, 405, & 1404
EVAP disabled P0440, 442, 443, 446, 449, 1441
Fuel tank pressure disabled P0452, 453
COT (catalyitic) overtemp delete
Fans disabled (using external fans) P0480, 481
T56 6speed
LS1, 02 F-Body
Rev limit at 6200rpm
Tires 225-70-14
Gear ratio 3.08
Thanks for any help/advice!
Old Jun 9, 2007 | 07:21 PM
hpmotorsports's Avatar
were are you located
Old Jun 9, 2007 | 07:22 PM
LS1-450's Avatar
Fastest way is to take it to a local tuner w/ a bench connector for the PCM. Could also send it to a mail order tuner & tell him what you want done. However, this would take a little more time.
Old Jun 9, 2007 | 07:32 PM
67rsss's Avatar
We are just north of the twin cities in MN. I don't know that the one we bought is going to be usefull. I have swapped a lot of parts between the two today in the hopes of saving the original PCM. At first, it looked like we may have just shorted a power supply, and I was hoping that if I could swap a few parts about, I would be able to get it running. Guess I was wrong. Should I try to put the parts back on the junkyard piece and plug it in? It is from a 00 Express van with a 4.3L, would it do anything when we hooked it up? I know it wouldn't run the car, and doesn't have VATS disabled, but would it at least turn on the SES and talk with an OBDII code reader?
We don't know any local tuners yet....
Old Jun 9, 2007 | 07:38 PM
well i would fix it for you , but i'm in florida sorry, wish i could help
Old Jun 9, 2007 | 07:39 PM
67rsss's Avatar
Thanks for the thought.
Old Jun 9, 2007 | 08:46 PM
bczee's Avatar
Not sure what you can do as a fix in a short time...
But if your just trying to fire it up and check all.. maybe someone in the area that has a PCM that has been flashed and setup in a simular setup as yours, will let you use it to fire it up for a day while you get a new PCM and Flashed.
Old Jun 9, 2007 | 09:27 PM
67rsss's Avatar
BCZEE, we don't know anyone around here. Moved here from CA a few years back. We are in the 55079 zip code if anyone is offering a bit of help.
I got the used PCM put back together, and even though it is for a 4.3L V6, I hooked it up, but we did not bother trying to start it. We get the check engine light, and there are codes to be read, which is more than we had before. We cycled it a few times and the fuel pressure built right up to 58psi. Found a minor leak, and marked it with masking tape for now. Even with the minor leak, it only dropped to 52psi after 10 minutes. We feel al ittle better, but are still pretty bummed. We are also a bit upset that the fuse didn't blow on the PCM harness. Kinda thought this type of thing is what fuses are for. We also have a small coolant leak at the S&P adapter in the pass head. Didn't put teflon on the threads, that is the ground for the sensor! We are thinking of just running a bit of Bars Leak through it when we get it running and see if that seals it up. Suggestions welcome.
Anyone here happen to be a tuner type in the twin cities area???
Old Jun 10, 2007 | 07:45 AM
dhutton's Avatar
This guy charges around $30 to reprogram and says he can do a one day turn. Maybe you could overnite it to him. I used him to rewire my factory harness - $300 including PCM reprogramming but I haven't received it back yet.
http://www.non-sponsor-link.com
Old Jun 10, 2007 | 08:54 AM
Stu Cool's Avatar
Wow, that really sucks. Personally I would call or email John at Speartech.com. He is my go to guy for anything electronic on the lsx motors.
Pat
Old Jun 10, 2007 | 09:39 AM
Whistler's Avatar
Sawzall and Welder Mod
"Tires 225-70-14"
Old Jun 10, 2007 | 10:09 AM
67rsss's Avatar
Hey, that is the closest to the stock size we are willing to go. They look right on the car, but are not launching pads by any stretch. The hardpart is using them to their fullest potential. The car needs a stocklike appearance from about 10 feet away. The traction bars are a common mod for the timeframe, so that is okay. This car is a lot of compromises, but was never intended to be a drag car.
Old Jun 10, 2007 | 10:17 AM
badjuju342's Avatar
Deranged Rat Fink
www.speartech.com
www.hptuners.com
Old Jun 10, 2007 | 12:43 PM
ls1stang's Avatar
Give jesse at wait4me performance a call. He's always helped me out.
Jamie
Old Jun 10, 2007 | 04:42 PM
67rsss's Avatar
Turns out the guy that we bought the engine and trans from has run into this problem before. He is programming a PCM for us and will mail it out to us as part of our warranty. We have been very, very happy with Performance Auto in SC. Very profesional, and apparently the free reprogram is supported under his warranty. We will call him first for the next swap.
Old Jun 10, 2007 | 09:37 PM
brans72ss's Avatar
67 is that near foley mn? i am up that way couple times a year it's a hour north of the cities right outside of st cloud. just curious might be moving that way in couple years (girlfriends family is there) just was curious how you liked it there.
Old Jun 10, 2007 | 10:38 PM
67rsss's Avatar
We are up 35 from the cities so Foley is about an hour to 1 1/2 hour from here. We love it here. I grew up about 9 miles south of here, and when while I was in the COrps, I was at Camp Pendelton. I somehow conviced my CA wife to move to MN, and she LOVES it. There are a few weeks in February that she hates, but that is it. There is so much to do here.
Old Jun 11, 2007 | 07:47 PM
brans72ss's Avatar
really i know lots of bars there (cheers) from the airport to foley is only a hour ride for us! i'll be up there again this coming new years and again in summer till she can get my southeren butt to move there!
Old Jun 11, 2007 | 09:03 PM
brans72ss's Avatar
Old Jun 13, 2007 | 07:43 AM
DLSNFL's Avatar
You might have tried TPIS in Shakopee?????
Not sure if they send out the re-programming though?
