LSX Fox
Thank you for your input! Did you use modified 4.6 motor mounts?
Do you have any pictures ?
Also which headers are you using?
I'm using stock replacement Hooker shorties, only because they were free, and they fit pretty nice once you cut off the stock triangle flanges.Here's the link to my original thread...
https://ls1tech.com/forums/conversions-swaps/286585-new-discoveries-ls1-into-mustangs-swaps.html
Now I am worried about one thing... The 4.6 kmember in a fox makes the car 1 inch wider on both sides right ???
Well if I'm wanting to upgrade my brakes to 03's cobra brakes (this mode makes you cars 1 inhc wider by itslef)
My car is gonna be 2 inches wider on both side.... I'm gonna have some issues arent I ?
If you plan on larger brakes and wheels then you want to use A-arms that are tubular versions of the stock 87-93 if going tubular/lightweight and if not tubular then just use the factory 87-93 5.0 Mustang a-arms. Then for spindles you will want to use the 94-95 Mustang GT or V6 spindles and hubs. These fit THE BEST and are not enough wider if at all to even mention. The 96-98 spindles will put the front end out approx. 1/4 per side and the 99-04 spindles are dang near 1/2inch and really just plain shouldn't be used....
Most K-members if not factory will require that you use a coilover kit. You can use factory or aftermarket arms with coil overs.
I am using fox width tubular a-arms from MMR and then the 94-95 spindles and Cobra brakes for my swap along with a UPR 4.6 K-member and modified 4.6 mounts and eveything looks/fits great and I can run 17x9 inch wheels up front and still be inside the fender well.
Hope my long *** post helped a bit...
Dave
Ok here is what i have in the garage right now. 99 GT K member, 03 cobra control arms, 03 cobra spindle and brakes. (shocks, springs and wheels yet to be bought)
I found a deal on s197 wheels and supposedly their offset would cancel out the effects of the wider track and I could run a 99-04 rear end as well. But I dont know if they will clear the cobra calipers.
I guess since I have all of this stuff I will just put it all together and install 96 cobra wheels from my buddys car and see what it looks like. If it's too bad I can get 94-98 spindles like you recommend.
What would you recommend for springs? I'm not building a drag purpose car, just building a street car and I want it to handle decently. The 4cyl springs seem way to soft for what I like. The car was mushy and was all over the road. I'd like a firmer ride yet comfy and I'd like the car to be a little lower but not slammed. I'd like an all around good street spring. I know it sounds wierd but I was thinking of using the stock front springs from a 99 cobra i found but I'm scared the car will be too high due to the lower weight of the body and drivetrain.
Good luck.
