Help on motor swap LS1+miata
Let us know what phase your in?
Ask a direct question and you get a direct answer!
What problems are you having now.
What options do you you think you have and if you want a opinon on it
Good luck
Dude......., there are a lot of good people on this board that offer assistance to just about anyone & everyone whom asks. Understaning that you're frustrated, specific questions in place of emotion, will serve you better.
My LS6 powered Miata was built from the ground up. The K frame, sub-frame bracing, suspension, & rear end are the most important parts required in building a successful LS6 powered Miata that drives & handles well. If your plan is to stick an LS1/T-56 into a Miata w/ a stock rear end & no suspension or frame modifications, I can't help. Handling will not be what it should be. Where is it that you need help?
