Engine/trans angle question.
For those who have had to fab their own motor and trans mounts, what is the best way to hold the engine in place while you determine the best angle to mount it at. I can't imagine using a cherry picker would be a good idea.
For the trans, I had to use a scissor jack and it worked fine.
Also what is the ideal surface on the engine for which to determine what angle the engine is sitting at.
All ideas are welcome
Cheers Robert
Then marked/tacked the mounts inplace. then took all out and made the final welds or drill holes as needed.
I found that the trans tail shaft or housing to be reading the same as the base PCV cover rail on the block. You can pertty much use any of the following. Front Crank, Trans Tail Shaft or housing, Block oil pan rail, PCV Cover Rail on the block. etc..as long as there are in line with the crank or 90 to the crank.
I just used the cherry picker and a load leveler for initial setup. Then sat it on the mounts and trans crossmember to finish it up.
I recently picked up a digital level to get a more accurate reading.
Is it safe to rest an Iron 6.0 mated with a T56 on the aluminum oil pan on the crossmember? With a wood block in between, of course. I’m worried about the oil pan cracking.
The oil pan is still in one piece.
