LS7 is alive
Old Jun 28, 2007 | 03:27 PM
95 Z28's Avatar
I forgot how clean engines look when they're brand new . Beautiful car man, can't imagine how much work went into that.
Old Jun 28, 2007 | 08:09 PM
ronald so's Avatar
wow
koni, dry sump, what do you got a 69 full out track car?! Looks beautiful, The small detail work is where is at, I can see all the detail you've put in. I bet putting those -AN lines puts a bruise on your thigh. I feel i havn't even given you enough compliments to commend you on a awesome build.
Good luck with your project.
Ronald
Old Jun 28, 2007 | 08:33 PM
WestSide's Avatar
Wow, just wow.
That 350 badge is a little deceiving
Old Jun 29, 2007 | 07:33 AM
XcYZb's Avatar
Originally Posted by ronald so
wow
Ronald
Thanks Ronald. I definitely want to do a bunch of PDE's when it's finished.
As for the 350 emblems, that's all coming off when it goes to paint.
Old Jun 30, 2007 | 02:46 PM
racecar's Avatar
That Rocks !!
What size are the header tubes? 1 7/8 or 1 3/4?
Old Jun 30, 2007 | 03:41 PM
capn smokey's Avatar
I am at a loss for words, that is an incredible car. Definitely magazine material.
Old Jun 30, 2007 | 03:54 PM
217zenki's Avatar
Badass.
Old Jun 30, 2007 | 05:44 PM
gixxer92's Avatar
Which front sub-frame are you using? I was looking at buying the Art Morrison front sub, do you have any opinions on sub-frames?
Also, are you going to powder coat or POR-15 the front subframe? And, are you using a 12 bolt or IRS in back with mini-tub?
Old Jun 30, 2007 | 10:52 PM
slammer454's Avatar
sick man, very clean, I bet it will be a beast on the road, I'll see ya on lateral g!
Old Jun 30, 2007 | 11:24 PM
XcYZb's Avatar
Originally Posted by racecar
That Rocks !!
They're 1 7/8".
It's a Wayne Due subframe with DSE control arms, Koni coilovers (550lb springs), Speedway Engineering sway bar with heim joints, ATS forged aluminum spindles that use the Vette bearing assemblies, AGR 12:1 road racing rack, etc. It's going to be painted black with a satin clear. The rear end is a Currie 9" with aluminum housing, nodular 9+ race case, 31 spline axles, etc. The suspension is a quadra-link which is similar to a 4 link, but all links have what's similar to a jonny joint for no bind in roll and uses an adjustable panhard bar for lateral location.
Thanks for the kind words, everyone.
Old Jul 1, 2007 | 01:51 AM
fuel_junkie's Avatar
I work my *** off to get to where I am today looking at a c5 vette at 20 years working 60hrs a week and still going to school. All I have to say is thanks lord for giving me my body to do what I do, I can see that you probably worked your *** as and it shows with a bad *** ride, one of the badest if not THE badest ride on here; mainly because of the sweat you put into it.
Old Jul 6, 2007 | 10:41 AM
  #32
FirstGen's Avatar
Scott, sent you a PM...
Old Jul 6, 2007 | 11:26 AM
  #33
diognes56's Avatar
:bow:
David
Old Jul 6, 2007 | 02:22 PM
  #34
Stu Cool's Avatar
Wow, what a great job! Can you tell us what those intake tubes were made from? Looks like a combination of a couple kits. It looks so clean
Pat
Old Jul 6, 2007 | 02:32 PM
  #35
XcYZb's Avatar
Thanks Pat. I made the intake plumbing from 4" mandrel U-bend steel tubing. I cut it with my metal cutting bandsaw, indexed it, and welded it up and painted it. I played around with a few different colors (silver, gloss black, satin black, etc), and I like the satin black the best. The silver (trying to somewhat match the aluminum) was just too much. Here's a better pic of the motor in the car:
Old Jul 6, 2007 | 02:42 PM
  #36
Compressor Surge's Avatar
Sooooooooooooo badazz!!!!!!
Old Jul 6, 2007 | 02:54 PM
  #37
a10beav's Avatar
Bad *** car!
Old Jul 6, 2007 | 03:23 PM
  #38
WILWAXU's Avatar
Beautiful setup!
Great work.
Old Jul 6, 2007 | 03:29 PM
  #39
ONEBADASSWS6's Avatar
That is awesome man
Very nice work.
Old Jul 6, 2007 | 03:33 PM
  #40
HOHN's Avatar
The best executed '69 Camaro I've ever seen...
