I need Help picking out a cam
hey guys I just need help picking out a cam trying to figure out what i can run and whats good out there. Here are the specs of the motor and car. I am looking for mild-rough idle, a powerband from 1,800-7,000 roughly not exact but in that area. I was looking at a few cams listed here.
Texas Speed
223/224 @.50 .566/.566 lift 1,600-6,400 choice of 114/112 lobe seperation
233/239 @.50 .595/.603 lift 1,900-6,500 choice of 113/112 lobe seperation
comp cams
222/224 @.50 .566/.568 lift 1,800-6,800
224/230 @.50 .581/.588 lift 2,000-7,000
Any other suggestions would be great in helping me.
Motor and car specs
4.10 gear with posi
25.7 Tall tire 12.6 wide
t-56 6 speed manual with 50% gear reduction in 6th gear
Motor
6.0L LS2 stroke out to a 402 c.i. 6.6L
4 inch stroke 3 inch bore all forged
Total seal gapless ring
clevite bearings
compression roughly 10.5-10.9
Heads are Dart, PRC,or AFr Heads
Intake is either BBk or Weind aluminum intake
motor will be N/a
this is in a 65 chevelle so if you need any other info let me know.
Thank
Randy
Texas Speed
comp cams
Motor and car specs
4.10 gear with posi
Motor
clevite bearings
motor will be N/a
Thank
Randy
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
