More 8100 Info Please.
Old Jul 16, 2007 | 10:47 AM
Durango_Boy's Avatar
Default More 8100 Info Please.
Okay, in regards to the 8.1L 8100 496, what are some of my accessory options like bracket configurations and oil pan?
This motor will be installed in a '74 Vette so the steering and suspension is a concern.
Will any of the other big block oil pans fit? I know some pans from the ZZ502 and ZZ572 fit in the C3 Corvette and I have seen several of the Mark V and Mark VI 7.4L 7400 454 in C3s as well. That would lead me to believe that some of the Vortec big block oil pans work in C3s and I just need to know which if not all would fit on an 8100.
I'm also wondering about brackets. Minimalistic is best. No A/C, and no smog. Just alternator, power steering, water, tension, and idle will be needed. The upper A-arms cause the most problems. I good reference is that a serpentine bracket kit from a '92 Camaro will fit just fine so long as the smog delete pulley and bracket are turned backwards. Not having anything there would be a plus.
Info is great guys and you all seem to have a lot of it.
Old Jul 16, 2007 | 02:04 PM
bczee's Avatar
I would say most of you normal Vette BBC accessories should work. As the 8.1 is just a new block and longer stroke over a older BBC 454 Mark V. Heads might be of a different design but should be able to swap most everything.
Old Jul 16, 2007 | 02:09 PM
Bryan @ Speed Inc.'s Avatar
new block meaning what? newly re-issued, or are there revisions to it's design???
Old Jul 16, 2007 | 02:17 PM
bczee's Avatar
reviesion of the design, one item was that in the Mark V they removed the Fuel pump housing, on the Mark VI, the put it back in. but search the internet for more information and history..
Old Jul 16, 2007 | 07:01 PM
Schitzo's Avatar
try this guys. They seem to know alot about the 8.1 motors.
http://www.raylarengine.com
Old Jul 17, 2007 | 07:30 AM
I emailed their tech department so thanks fior the suggestion.
Old Jul 17, 2007 | 12:15 PM
Believe it or not there does not seem to be that much that's easily found without going through obscure sites that seem to have no connection to the project at hand.
Old Jul 18, 2007 | 07:59 AM
jmarsa's Avatar
Not sure how obscure these are:
http://en.wikipedia.org/wiki/Chevrolet_Big-Block_engine
http://en.wikipedia.org/wiki/GM_Vortec_engine#8100
--JMarsa
Old Jul 18, 2007 | 08:01 AM
Originally Posted by jmarsa
Yeah those were some of the first places I looked when I got going on this project. I appreciate the help.
Old Nov 22, 2007 | 09:10 PM
kwplot34's Avatar
You forgot to mention that you will be putting 2 alternators on your car.
Old Nov 22, 2007 | 09:29 PM
big2bird's Avatar
Gotta have enough power for the dual wiper pumps.
Old Nov 22, 2007 | 09:34 PM
kwplot34's Avatar
Yip,thats probably why he is going to a BB,to turn the twin alt's,and don't forget to turn the twin smog pumps to work his headlights
Old Nov 23, 2007 | 01:45 PM
pist0lpete's Avatar
From what I understand the aluminum 8.1L has little to nothing to do with the previous big block engines. It is basicly a big block version of the LS1. It has a different cam crank all internals and I wouldn't be surprised if the exterior bolts for the accessories etc. are different as well. There is one or two companes that make cams a port heads for them but they are expensive. I think the lack of aftermarket support is why nobody seems to use these engines for swaps.
Old Nov 25, 2007 | 11:44 PM
big2bird's Avatar
big2bird: post constructive feedback please, not misquotes and negative comments
Last edited by G-Body; Nov 27, 2007 at 01:02 AM. Reason: Removed disrespectful comments
Old Nov 26, 2007 | 12:10 PM
Bo185's Avatar
It's not aluminum! The blocks iron as well as the heads.
Old Nov 27, 2007 | 01:08 AM
G-Body's Avatar
sawzall wielding director
Lets try to keep this thread on track
Old Nov 27, 2007 | 11:00 AM
bczee's Avatar
The 8.1L (RPO L18) is new or Redisigned generation of the BBC, It has been redesigned to use new and simular technology as/from the LSx family of engines (ie. Coil on plug, EFI/Intake, on piece rear seal, Roller Cam, etc). but for the most part, it is still a Tall deck BBC, same bore center but stroked to bring it out to 496cid.
Heads are still the canted (porcupine valves arrangement) but redesigned.
Old Nov 27, 2007 | 01:36 PM
TimAT's Avatar
Forgive me for asking, but I'm curious. why hunt around for stuff to make an 8.1 go, when you can get an "out of the box" 8.2 that's already a proven thing and has loads of parts already on the market? The 8.1 is 496 cubic inches, and the 8.2 is a 502. The 502 is a standard 9.8 deck block, meaning it'll fit lots of places the 8.1 will not without major surgery. If it's cubic inches, then there's always the 572.
Not trying to rain on the parade at all, just curious.
Old Nov 27, 2007 | 03:22 PM
Easy. I found a complete take out 8100 for almost nothing compared to what a 502 would cost.
It was a budget build project. Turned out the budget called for cuts, and a Vortec 350 was chosen for the build.
Old Nov 28, 2007 | 07:25 PM
big2bird's Avatar
I will comply .
