Alt only on a 5.3
Old Jul 16, 2007 | 04:32 PM
1987earthquake's Avatar
Default Alt only on a 5.3
I want to temporarily run just an alternator on my 5.3 until I get the money up for the brackets I want. Is there anyone out there that is running just an alt on the truck brackets? pics would be great.
Thanks,
Eric
Old Jul 22, 2007 | 08:22 PM
team39763's Avatar
I'm wondering the same thing. I've seen it on somebody's car, but I can't find them right now. If I get ahold of them I'll let you know what I find out.
Old Jul 23, 2007 | 08:14 AM
Come on guys I know someone has done this.
Old Jul 23, 2007 | 11:04 AM
bczee's Avatar
I have only seen someone do a LS1 F-Body Alternator only.. They just got a belt that was the correct size and just had the top passenger idler, water pump, crank and Alternator.. was not the greatest but it worked.
Crank > Idler > under water pump pulley > top of Alternator > bottom of Crank pulley.
Have not seen anyone post any setup like this. But I am looking at a picture of the truck setup. You could try and get shorter belt and run it this way, try with a string to see if it will route correctly. leaving the alternator as is, remove the AC and Power Steering pump (cut up mount if needed). just measure the string after and get belt that long.
Bottom of Crank > passenger side Idler > Top of Alternator > under Idler > top of Water pump > counter clock wise to the driver side of crank pulley and around to start again..?? Looking at the picture all of the pulley rotation would be in the correct direction and it doesn't appear that anything would get in the way.
[IMG][/IMG]
hope it works.. post if it does.. !
Old Jul 23, 2007 | 01:03 PM
I just got rid of my brackets because the p/s pulley hit the steering box and the alt hit the hood even with a 6" cowl!! It was out too wide. I also got rid of the tensioner. I was wondering if someone had made a bracket out of some flat bar or something similar to run the alt with the water pump and crank. This will only be temporary on mine since I will be getting s&p's relocation setup to put my ac up high. Any ideas
Old Jul 23, 2007 | 01:26 PM
bczee's Avatar
You can alway make the bracket out of flat bar, alum/steel plates or round stock. but you have a problem of the Water pump not being in the same rotation as the Crank. You would need to rid up a tensioner/idler aso so the belt can be looped around something to get the pump going in the right direction.. almost like a V with the alter on one side and a idler on the other side with the belt going under the pump pulley.
You can try making templates out of wood first, then transfer to metal.
If you going to get the S&P relacation setup. Why not just charge it on a credit car or have someone lend you the funds. Considering the time and money you might have to put into just making something temporary.
Old Jul 23, 2007 | 01:39 PM
Got the material and stuff to make it and time would be while I'm at work... I just was wondering if someone else had already come up with a design for a bracket already.
Old Jul 27, 2007 | 01:01 PM
So no one has done this before?? I find that hard to believe...
Old Jul 29, 2007 | 07:37 PM
nova65ss's Avatar
Any update on this I need one too. I bought the carshop kit and didn't realize it only worked w/ a carb got a little too excited after looking everywhere for one with no luck.
The guy in the T bucket thread used an F body part but I am a little confused on how he did it.
Thanks,
Old Jul 29, 2007 | 09:39 PM
Ionize's Avatar
I'm running it on my t-bucket, its an f-body setup-standard waterpump, f-body 105 amp alt w/f-body bracket, f-body idler, f-body crank pulley, belt #napa 25-060551
Old Jul 30, 2007 | 07:56 AM
Any idea on truck accessories? I have the w/p and the crank pulley and the truck alt..
Old Jul 30, 2007 | 03:20 PM
Ionize, post some pics of your setup maybe I can use it to get an idea. Only big thing is the water inlet on the pump comes out the top on the truck water pump.
Old Jul 30, 2007 | 03:55 PM
Ionize's Avatar
That pic shows about all there is, after going under the waterpump it goes on top of the tensioner then down to the crankpulley, then alt, etc.. All f-body parts.
Old Nov 23, 2007 | 04:59 PM
Carshopinc.com's Avatar
LS1TECH Sponsor
Thanks,
This is incorrect our kit works with injected motors as well just not with DBW configurations.
Old Nov 23, 2007 | 08:33 PM
jay_lt4's Avatar
all i run on my 6.0L is the alt and water pump, very simple:
